Center of mass of a non-uniform rod
The discussion focuses on calculating the center of mass of a non-uniform rod with a linear density defined by λ = ax². To find the total mass M, integration is performed, resulting in M = (1/3)aL³. The participants clarify that the center of mass x_cm can be determined using the formula x_cm = (1/M)∫ x dm, where dm = ax² dx. Confusion arises regarding the integration limits and the correct expression for x in the context of the problem. Ultimately, the importance of correctly expressing dm in terms of dx is emphasized to solve for x_cm accurately.
Linus Pauling
1. A straight rod has one end at the origin and the other end at the point (L,0) and a linear density given by \lambda=ax^2, where a is a known constant and x is the x coordinate. Since this wire is not uniform, you will have to use integrtation to solve this part. Use M=\int_0^L dm to find the total mass M. Find x_cm for this rod.
2. X_cm = (1/M)Integral(x dm)
3. To obtain M, I did a*Integral(x^2 dx) from 0 to L, obtaining M = (1/3)aL^3
I then did x_cm = (1/M)*a*Integral(x^3) from 0 to L, obtaining:
(3/4)(a^2/L)
Apparently the answer does not depend on a
Ok, I am confident that my calculation of M is correct
M = (1/3)aL^3
But what is the next integral I need to do? I know it's (1/M)*Integral(x dm)
where dm = ax^2 dx. What is x? I'm going psycho.
What do you mean, what is x? It's the x-coordinate along the wire, just like before. Just write dm in terms of dx (like you just did) and you'll have what you need to integrate.
I do not understand. The length of the rod is L. So if I integrate L*ax^2 dx from 0 to L I obtain (1/3)aL^4.
Dividing by M=(1/3)aL^3 I obtain L, which is incorrect.
:confused: Why are you integrating that?
x_cm = (1/M) ∫ x dm, just like you stated in your last post. Just write dm in terms of x, which you also stated in your last post.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
