Center of Mass with Circle that has a Cut Out
To find the center of mass of a 5kg circle with a 2m radius cut out, consider the cut-out circle as having negative mass. The center of mass can be calculated by determining the mass distribution of the remaining shape. The approach involves using the formula for the center of mass of composite shapes, factoring in the negative mass of the cut-out. Understanding the relationship between the full circle and the cut-out is crucial for solving the problem. This method allows for the correct calculation of the center of mass for the modified shape.
SerhanFT9
Find the center of mass of a 5kg circle with a radius of 4m with a circle that has a radius of 2m cut out from it.
To be completely honest, I do not know where to start. I do know how to find the center of mass when you have points on a plane. But I cannot seem to find the connection between this and that.
Thank you
Welcome to PF!
Hi SerhanFT9! Welcome to PF! :smile:
You can treat the hole as a solid of negative mass. :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
