How Do You Calculate Total Acceleration of a Particle on a Circular Path?
To calculate the total acceleration of a particle on a circular path, first determine the tangential velocity after 3 seconds using the acceleration of 4.3 m/s², resulting in a velocity of 12.9 m/s. The centripetal acceleration at that moment is found using the formula a = v²/r, yielding 9.245 m/s². The total acceleration is then calculated as the vector sum of the tangential and centripetal accelerations, which are perpendicular to each other. This results in a total acceleration of approximately 10.196 m/s².
Sheen91
A particle starts from rest at t=0 s.
It moves along a circular path of radius 18m and has an acceleration component along its path of 4.3m/s^2.
What is the magnitude of the acceleration when t=3 s?
N/A
I am not sure how to start. If the particle is accelerating at 4.3m/s^2 at t=0s then will it not be at that same acceleration at t=3 s?
I am sure it is not a trick question, as I know the acceleration will start out along the path of the particle and then the acceleration will point inward toward the center of the circle path.
Any and all help will be much appreciated.
Cheers
Find the velocity of the particle after 3 seconds by using relevant kinematic equation. Then find the centripetal acceleration a that instant. The net acceleration of the particle is the resultant of the tangential and the radial acceleration.
Thank you so so much. Trying that now.
so
magnitude of acceleration = v^2/r
Acceleration is 4.3m/s^2 so at t=3 s
v = 4.3 x 3 = 12.9m/s
mag of acc = 12.9^2/18 = 9.245m/s^2
Does that seem right? Just want to double check before submitting :D
so
You are right. Now find the resultant of 4.3 m/s^2 and 9.245 m/s^2
9.245 m/s^2 is normal to 4.3 m/s^2
so you would just do this?
\sqrt{4.3^2 + 9.245^2} = 10.196 m/s^2
You are right.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
