How Does Banking Angle Affect the Radius of an Airplane's Turn?
The discussion focuses on calculating the distance from an airport while a plane is banking during a turn. The pilot maintains a speed of 450 mph at an altitude of 20,000 ft, banking the plane at a 10-degree angle. Initial calculations suggested a radius of 118.03 ft, but after correcting the velocity squared, a new radius of 77,904 ft was determined, leading to a total distance of approximately 15 miles from the airport. Participants clarify the lift force, emphasizing that it should not simply be equated to weight, and suggest using the correct equations to solve for the radius and distance accurately. Overall, the conversation highlights the importance of proper physics principles in aviation calculations.
mcgooskie
In this problem I need to figure out how far I am from the airport.
The pilot tells us that we have to circle the aiport before we can land. We will maintain a speed of 450mph at an altitude of 20,000ft. while traveling in a horizontal circle around the airport. I notice that the pilot banks the plane so that the wings are oriented at 10deg to the horizontal. An article in the in-flight magazine says that planes can fly because the air exerts a force "lift" on the wings which is perpendicular to the wing surface.
So:
V=660 ft/s
h=20,000 ft
bank = 10deg to the horizontal
So I drew a FBD with my normal force perpendicular to my wings, which were banked to the horizontal.
Sum Fx=Wx=ma where a=v^2/r
sin10 (mg)=mv^2/r (mass drops out)
sin10 (32.2ft/s^2)=(660ft/s)/r
solving for r=118.03ft
add that to the current altitude of 20,000ft gives a distance of 20,118ft from the airport?
It doesn't seem like this problem could be this "easy". I feel like I am totally missing a point here.
Thanks!
oops! I forgot to square my velocity. That being said, I have a new r=77,904ft.
If you figure 77,904 as the x value of a right triangle, and 20,000 as the y value, then the hypotenuse or distance from the airport would be 80,431ft or approx 15miles. This sounds more reasonable?
Why have you taken "mg" as your lift force?
Take another look!
It seems from what you wrote above, the force F that is giving the plane lift has magnitude of mg. This is clearly not true.
Using F = ma in the vertical direction gives
0 = Fcos(\theta) - mg \rightarrow F = mg/cos(\theta)​
where \theta is the bank angle.
Plug this F back into what you have above, solve for r, use the pythagorean theorem and you're done.
e(ho0n3
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
