Solving Derivative of ln[cos(w-1)]: Need Help!
  • Thread starter Thread starter dec1ble
    Derivative
To find the derivative of f(w) = ln[cos(w-1)], the chain rule must be applied. The derivative of the logarithmic function is 1/cos(w-1), and the derivative of cos(w-1) is -sin(w-1). Therefore, the overall derivative becomes -sin(w-1)/cos(w-1), which simplifies to -tan(w-1). The confusion arises from not correctly applying the chain rule and simplifying the terms. Understanding these steps will lead to the correct answer of -tan(w-1).
dec1ble
I am presenting a problem in front of the class tomorrow and I am slightly confused on the steps for my problem. The problem is:
Find the derivative of the given function
f(w) = ln[cos(w-1)]
The answer in the back of my book shows the derivative is -tan(w-1) - but I'm my steps aren't giving that answer - could anyone show me the steps to use in order to get that answer? Thanks a lot!
f(w) = ln[cos(w-1)]
Break it down:
Suppose have a function of x as u(x) and have the expression:
ln[u(x)]
Would you not, using the chain rule, take the derivative of the logarithm which is \frac{1}{u(x)}, then take the derivative of u(x) to get:
\frac{1}{u(x)}u^{'}
Same dif with the cosine of a function right? Derivative is minus the sine of the function times the derivative of the function. In your case, it's nested three times (well w-1 is a function of w in which the derivative is just 1).
if i have \frac{d}{dx} \ln u = \frac{1}{u}
then i find d/dx cos(w-1) = -sin(1)
then plug that into the u?
so 1/-sin(1) - then I am stuck
