Challenging High School Planetary Mechanics Problem
The discussion revolves around solving a planetary mechanics problem involving a binary star system with two stars of different masses. The key challenge is determining the common period of revolution, requiring the application of gravitational and centripetal force equations. Participants express confusion about the different distances (r) in the equations and the importance of identifying the center of mass for accurate calculations. There is also a debate on whether a sketch is necessary for visualizing the problem and finding the center of mass. Understanding these concepts is crucial for arriving at the correct solution for the period of revolution.
forcefrom
A certain binary star system consists of two stars of masses m and 3m respectively separated by a distance of 1.5 * 10^12 m measured between their centres. These stars revolve in sync with each other around their common centre of mass. If the smaller star has a mass of 1.0 * 10^30 kg, what is their common period of revolution?
r = 1.5 * 10^12 m
m1 = 1.0*10^30 kg
m2 = 3.0*10^30 kg
Fg = Gmm/r^2
Fc = 4mpi^2r/T^2
Initially, I thought I could do Fc = Fg and solve for period, but I'm not sure if that's the right way to do it and it doesn't sound right either.
Your method is correct in principle. A slight complication is that the r's in both equations are different. One is measured from the center of revolution, another is the distance between the bodies. Which one is which and how are they related?
Oh, so the r in Fc is different. Center of revolution means I need to know my center of mass, right? Another problem I'm having is I'm not sure exactly how the sketch for this works, if that's needed at all?
Yes, you need to find out the C. M. I am not sure what your problem with the sketch is.
Do I need a sketch (to know visualize/see the diagram of the problem) to find the C.M.? I'm not sure how to find it.
What is the definition of the C. M.?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
