Challenging Integrals in Calculus 1-2: Expand Your Problem-Solving Skills!
  • Thread starter Thread starter pakmingki
    Hard Integrals
  • #151
\int{\sec^{3}{\theta}\mbox{d}\theta}
If you use u=\csc{\theta} substitution you will have to do the partial fraction decomposition
u=\sec{\theta}+\tan{\theta} will also work
If you prefer reduction formula use it
  • #152
This one's super easy (I encountered it while trying to find the arc length of ##y=x^2##).
(1) ##\int sec^3 \theta\ d\theta = \int sec^2\theta\ sec \theta\ d\theta##. Integrating by parts, we get
(2) $$sec \theta\ tan\theta - \int sec\theta\ tan^2 \theta\ d\theta=sec\theta\ tan\theta - \int sec^3\theta\ d\theta +\int sec\theta\ d\theta$$
So (3) $$\int sec^3 \theta\ d\theta = \frac1{2}(sec\theta\ tan\theta + \int sec\theta\ d\theta)$$
Let's solve the integral of ##sec\theta## on the right. Multiplying the denominator and numerator by ##cos \theta##, we get
(4) $$\int \frac{cos \theta}{cos^2 \theta} d\theta = \int \frac{cos \theta}{1-sin^2 \theta} d\theta$$
Factorizing the denominator, we get (5)$$\int \frac{cos \theta}{(1+sin \theta)(1-sin\theta)} d\theta$$
This can be rationalized to give (6)$$\int \frac1{2} (\frac{cos \theta}{1+sin\theta}+\frac{cos \theta}{1-sin\theta}) d\theta$$
Let ##u=sin \theta##. Then ##du=cos\theta\ d\theta##. So our integral expression becomes from (4) becomes $$\frac1{2}(ln|1+sin\theta|-ln|1-sin\theta|)$$,which is the same as writing $$ln \sqrt{\frac{1+sin \theta}{1-sin\theta}}$$ If we multiply the numerator and denominator by ##1+sin\theta##, we get the lovely expression
$$ln \sqrt{\frac{(1+sin\theta)^2}{(cos \theta)^2}}=ln|\frac{1+sin\theta}{cos \theta}|=ln|sec\theta+tan\theta|$$
Making the final substitution into (3), we get ##\int sec^3 \theta\ d\theta = \frac1{2}(sec\theta\ tan\theta + ln|sec\theta +tan\theta|)+c##, where ##c## is an arbitrary constant. IMO, this is too trivial a question to appear in this thread. If you really want to push things up a notch though, try the double integral of ##sec^3x## :rolleyes: (It uses elliptical integrals, and I myself don't have the slightest clue how to solve it)
  • #153
AdityaDev said:
Or this one
##\int_0^{\pi/2}sinxlnsinxdx##
Now you can't split the integral.
This is an improper integral. Calculating the indefinite integral is very easy, and this question has more to do with limits than the actual process of integration. In general, using approximate methods is suitable to calculate the numerical value of such functions (although if you want to get very specific, then the question is not correctly presented, as the upper limit is not part of the integrand's domain [a limit must be shown in formal treatment]).
  • #154
Well, if we are discussing ##\int \sec^3 (\theta) d\theta## then there is also
##\int \frac{1}{\cos^3(\theta)} d\theta = \int\frac{\cos(\theta)}{\cos^4(\theta)} d\theta = \int \frac{\cos(\theta)}{(1-\sin^2(\theta))^2} d\theta = \int \frac{1}{(1-u^2)^2} du##
The last integral is tedious but not hard (I've seen it given as a Calc 2 assignment question).
Unfortunately the OP restricted the thread to Calc 1-2 level. There's only so much variation of the basic techniques you can do.
  • #155
integral from zero to x sin(x^2) is called (fresnel integral) .
the full solution is here.
  • #156
A must-do preliminary exercise:
$$\int arcsin(x)\ arccos(x) dx$$
  • #157
That's really easy if you remember that :-
##arcsin(x)+arccos(x)=\frac{\pi}{2}##
then substitute ##x=sin(y)## to get:-
##\int y(\frac{\pi}{2}-y)cos(y) dy##
Here's a good proof of the Gaussian integral that I quite like because at first sight it seems that something is wrong, but the proof is mathematically sound.
Let ##I## be the Gaussian integral then we have:-
##I^2=\int_0^{\infty}e^{-x^2}\int_0^{\infty}e^{-u^2} du dx=\int_0^{\infty}e^{-x^2}\int_0^{\infty}e^{-x^2y^2} x\ dy dx\\
=\int_0^{\infty}\int_0^{\infty} xe^{-x^2(1+y^2)} dx dy\\
=\frac{1}{2}\int_0^{\infty}\frac{1}{1+y^2} dy\\
=\frac{\pi}{4}.##
  • #158
∫ f(x) dx = F(a) - F(b)
  • #159
The left hand side is the indefinite integral of f, but the right hand side is a constant. The only function that integrates to a constant is the zero function.
  • #160
PWiz said:
If you really want to push things up a notch though, try the double integral of sec3xsec^3x :rolleyes: (It uses elliptical integrals, and I myself don't have the slightest clue how to solve it)
This integral is not expressible in terms of elementary functions.
##\iint sec^3(x) dx\ dx=\int\frac{1}{2}[sec(x) tan(x)+ln(sec(x)+tan(x))]+c\ dx\\
=\frac{1}{2}sec(x)+cx+\frac{1}{2}\int ln(sec(x)) dx +\frac{1}{2}\int ln(1+sin(x))dx##
Now note that:- ##1+sin(x)=2cos^2(\frac{\pi}{4}-\frac{x}{2})\\
\therefore ln(1+sin(x)=ln (2) -2 ln(sec(\frac{\pi}{4}-\frac{x}{2}))##
and with a simple substitution this integral should be of the ##ln(sec(x))## type.
However ##I=\int ln(sec(x)) dx## is not elementary, see this.
  • #161
I know that. It's why I mentioned in my earlier post that it's expressed in terms of "elliptical integrals" and that I can't solve it. In general, I solve out every integral I can on my own unless it's non-elementary, in which case I don't even make an attempt.
  • #162
I don't see how ##I=\int ln(sec(x)) dx## can be reduced to an elliptic integral...
[EDIT:- remember that elliptic integrals are of the form ##\int\frac{A(x)+B(x)\sqrt{S(x)}}{C(x)+D(x)\sqrt{S(x)}} dx##]
  • #163
You're right, it uses the polylogarithmic function. But the fact that it's non-elementary is enough to keep me from trying o0)
  • #164
Try this one $$\int_{0}^{\pi/2}{ dx \over {1+\tan^{2015}{x}}}$$
  • #165
Why specifically to the power of 2015?
  • #166
Here are some I like. First one is one that I stumbled upon while trying to integrate \exp(-a_1^2x^2 - a_2^2y^2) over a circular area.
The second is one that I found was really cool and educational to figure out by myself
Try this:
\int_0^{2\pi} \exp(-a\cos^2\theta)dx.
Or this:
\int \exp(ax)\sin(bx) dx.
Hint for no.1:
\int_0^{2}\frac{\exp(-px)}{\sqrt{x(2-x)}}dx = \pi\exp(-p)I_0(p).
  • #167
dextercioby said:
\frac{(1-x)^2 (1-x)^2}{(1-x)^2 + 2x} = (1-x)^2 - \frac{2x(1-x)^2}{(1-x)^2+2x} = (1-x)^2 - 2x\frac{1-x^2}{1+x^2} + \frac{4(1+x^2)-4}{1+x^2}
The integration of the 4 terms is elementary.
\frac{(1-x)^2 (1-x)^2}{(1-x)^2 + 2x} = (1-x)^2 - \frac{2x(1-x)^2}{(1-x)^2+2x} = (1-x)^2 - 2x\frac{1+x^2}{1+x^2} + \frac{4(1+x^2)-4}{1+x^2}
I think this is correct
  • #168
Indeed, you are correct.
  • #169
Hi guys...In this 3D I found a lot of interesting posts with amazing solution integrals, other difficult but very boring and other too easy to be interesting. One of the most amazing I found is the following:
$$\int{{\sqrt{tan x}dx}}$$
Here is an example of easy but nice to do:
$$\int{ dx \over {x\sqrt{x^2-a^2}}}$$
$$(-1/a)\int{ -a\over {x|x|\sqrt{1-|a/x|^2}}}dx$$
$$(-1/a)\int{ 1\over {\sqrt{1-|a/x|^2}}}d(|a/x|)= (-1/a) arcsin|a/x| +C$$
  • #170
You should try the integral and find out for yourself!
  • #171
maka89 said:
Try this:
##\int_0^{2\pi} \exp(-a\cos^2\theta)dx##.
NOTE:-To anyone attempting this one, you will need the hint unless you already know about Bessel functions.
The first integral of this type on this thread I believe... the answer is ##\frac{\pi}{4}##
##\int\sqrt{tan(x)} dx##​
'tis been already posted on this thread.....
maka89 said:
Or this:
##\int \exp(ax)\sin(bx) dx##.
'tis easy...just do integration by parts twice on ##e^{ax}##...
Come on lads give us something good......[like that ##sin(x^2)## integral, that was simply amazing......]
  • #172
@certainly...that's exactly what I said...It is one of the most amazing I found HERE!
  • #173
\int{{\sqrt{1-e^{2}sin^{2}(\theta)} d\theta}}
  • #174
Hint: it's an elliptic integral of the second kind.
  • #175
This one might be a little more approachable...
\int{ x^2-3x+7\over {(x^2-4x+6)^2}}dx
  • #176
zoki85 said:
Hard ,but famous and bautiful :
\int_{0}^{\infty}sin(x^2)dx
I believe this uses multivariable calculus since I recall you must first prove the definite integral of the e^-x^2 which requires double integrals and a change of variables.
  • #177
DyslexicHobo said:
I'm just out of Calc 1, so I'm not sure if I even have the knowledge to solve this... but here's where I am now. I can't tell if I complicated it even more, or if I'm closer to getting the solution.
\int (r-1)^{1/5}ln(r) - r^{-1} (r-1)^{1/5} dr
I used u-substitution (well, r-substitution), where r = x^5 + 1. After the substitution I used integration by parts, and now I'm unsure if that was even the right path. Please let me know!
And please tell us how to do \int_{0}^{\infty}sin(x^2)dx
I think you need multivariable to do that.
  • #178
Here is a hard nut to crack. Been trying to solve it for a while, can't confirm it's actually solvable.
1/ ( x ( ln (x+1) -1 ) )
  • #179
x^2arctan(5x)
  • #181
$$\int_{0}^{\pi}\frac{cos(nx)-cos(na)}{cos(x)-cos(a)} dx$$
and
$$\int_{0}^{\infty }\frac{x}{e^{x}-1} dx$$
  • #182
Try this.
  • #183
it should come from common sense i think. seems the analytical method is going to be just WOOW
  • #185
yip said:
Try \int{\frac{(1+x^{2})dx}{(1-x^{2})\sqrt{1+x^{4}}}}
(forgot to put the integral sign in, it is now fixed)
This is my answer, tell me if i did something wrong :).
  • #186
this is a “simpler” result I got from unraveling your solution & re-packaging it. I want to figure out how to get it in this form in a more natural way. As of now I’m stuck. Right now I’m working with a Pythagorean triangle
Adjacent = 1-x^2
Opposite = x*sqrt(2)
Hypotenuse = sqrt(1+x^4)
and the solution is 1/sqrt(2)*ln(sec(angle)+tan(angle)) + C
I see some kind of pattern here but it’s a little opaque. Any way to clear this up & produce a really elegant solution?
  • #187
Try:
\int_{0}^{1} e^{-x^{x}} dx
Ssnow
  • #188
try the integral of sin(lnx) by using eulers formula
  • #189
The answer is
<br /> \frac{1}{2\sqrt{2}}\ln \left| { \frac{\sqrt{2}+{\sqrt{x^2+\frac{1}{x^2}}}} {\sqrt{2}-{\sqrt{x^2+\frac{1}{x^2}}}}} \right|<br />
  • #190
Is It -sqrt(pi/2) took me a bit to calculate. Its doable, If one knows the tricks
  • #191
Try this one:
##\int_0^\infty\frac{\sin^2x}{x^2(x^2+1)}dx##
If you need an explanation, let me know. But I want to give you guys some time to find out how to do it
  • #192
As my first calculus teacher said, "there is a difference between a hard problem and a long problem."
  • #193
Is this directed toward my integral? If it is, I could take it down from this thread.
  • #194
Actually, I can't delete that post.
  • #195
Here's another integral that I find interesting $$\int_0^\infty\frac{\sin x}{\sinh x}dx$$This one has an answer in terms of hyperbolic cotangent.
