Change in internal energy of gas (thermodynamics)
The change in internal energy (ΔU) of a gas during a thermodynamic process is path-independent, meaning it remains constant between two states (A and B) regardless of the path taken. In adiabatic conditions, where heat transfer (Q) is zero, the work done is the only factor affecting ΔU. The discussion clarifies that one cannot achieve different work outputs while maintaining the same ΔU when transitioning between states A and B. Any variations in pressure and volume will result in different final states and corresponding changes in internal energy.
  • Understanding of thermodynamic principles, specifically the first law of thermodynamics.
  • Familiarity with adiabatic processes and their implications on internal energy.
  • Knowledge of work done in thermodynamic systems and its graphical representation.
  • Basic grasp of state functions and path functions in thermodynamics.
  • Study the first law of thermodynamics and its mathematical formulation.
  • Learn about adiabatic processes and their characteristics in detail.
  • Explore graphical representations of work done in thermodynamic cycles.
  • Investigate the differences between state functions and path functions in thermodynamics.
Students and professionals in physics, engineering, and thermodynamics who seek to deepen their understanding of internal energy changes and adiabatic processes.
axe34
Hi,If the change in U between 2 points (A,B) in a thermodynamic process is always the same despite the path, then please help with the following:
Say I have adiabatic conditions so that delta U = Work done only (Q=0)
Surely I can go through multiple paths between A+B with increased or decreased amounts of work? Then how can the change in internal energy be the same each time?Thanks
Science news on Phys.org
Actually, you can't go adiabatically through multiple paths between A and B with increased or decreased amounts of work. If you think you can, please provide one specific example.
Chet
Say I want to decrease pressure and volume from A to B.
Could I not drop the pressure immediately, then reduce the volume at this constant pressure. The area (work) of this graph would be less if I did a smooth transition between A + B, would it not?
You can't decrease both pressure and volume adiabatically. But, suppose you wanted to decrease the imposed force per unit area immediately, and then let the volume increase adiabatically at this force per unit area. Option 2 is to do a smooth gradual transition between the initial pressure and the force per unit area you used in Option 1. The final temperature and the final volume under Option 2 would be different from the final temperature and the final volume under Option 1, the work would be different, and the change in internal energy (determined by the change in temperature) would be different. You could not reach the same final equilibrium state under Option 2 as you did under Option 1.
Chet
  • · Replies 22 ·
  • · Replies 135 ·
  • · Replies 60 ·
10K
  • · Replies 16 ·
