Change in Kinetic energy / Momentum
The problem involves a truck's change in kinetic energy and momentum as it accelerates while changing direction. The truck's mass and initial and final velocities are provided, prompting calculations related to kinetic energy and momentum in a two-dimensional context.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to convert speeds to standard units and the importance of treating momentum as a vector, questioning how to properly account for direction in calculations.
Some participants have provided hints regarding unit conversion and vector components. There is acknowledgment of the need for a vector approach to resolve the problem, particularly in calculating the change in momentum.
Participants are navigating the complexities of vector addition and subtraction in momentum calculations, indicating a need for clarity on how to handle directional changes in the context of the problem.
R.H.2010
A 2800 kg truck traveling north at 35 km/h turns east and accelerates to 55 km/h.
What is the change in the truck's kinetic energy?
What is the magnitude of the change in the linear momentum of the truck?
What is the direction of the change in the linear momentum of the truck?
I know the change in something is Final minus initial, and i have been using momentum=mass times velocity , Kinetic Energy = half mass times velosity's square, but I'm still not getting the right answer. Any suggestions please? Thank you.
Show what you've done so we can see where you went wrong.
Hints: Make sure you convert the speeds to standard units, like m/s. Also, remember that momentum is a vector; direction matters.
a) I finally got this part after paying attention to units.
b) (2800)X(550/36) - (2800)X(350/36)
reading your hints: what do you mean to deal with velocities as vectors in momentum equations?
c) I know I will have to use arctan, but it looks like I'm missing the vectors part that i will need to do c.
That equation is not valid since the initial and final momenta are in different directions. You have to use components and subtract the momenta as vectors, not just numbers.
c) I know I will have to use arctan, but it looks like i'm missing the vectors part that i will need to do c.
Exactly. You need the vector stuff to do parts b and c.
Do this. Call east the +x axis and north the +y axis. Now find the x & y components of the initial and final momenta. Then you can subtract them as vectors and find the magnitude and direction of the change in momentum.
It worked. Thank you very much.
  • · Replies 22 ·
