Understanding Basis Change with Hamiltonian Matrices
aaaa202
We are given the vectors la> = (1,0) and lb> = (0,1) and then a Hamiltonian H which is a 2x2 matrix with 2 on the diagonal entires and zero elsewhere. I am asked to now represent H in the basis of the vectors la'> = 1/sqrt(2)(1,1) and lb'> = 1/sqrt(2)(1,-1), which are also eigenvectors of H because of the degeneracy of the eigenvalues of H.
I always get confused with these basis-change problems. First of all: What does it even mean that a matrix is represented in a particular basis? Why is H necessarily represented in the basis (1,0) and (0,1)?
Secondly I know that the basis change equation is:
H' = SHS^-1 (1)
But my QM also tells me that the elements of H' can be found by taking the inner products <a'lHla'>, <a'lHlb'> etc. How is this equivalent to (1)?
See this FAQ post: https://www.physicsforums.com/threads/matrix-representations-of-linear-transformations.694922/
Okay but I am still not sure why for an orthonormal basis the basis change equation:
B = SAS^-1
Reduces to just calculating B using the equations B_ij = <bil A lbj> , where b1,b2,b3... are the new basis vectors of the new basis expressed in the old basis.
I didn't have time to answer that before. Let U be the linear operator that takes the old basis vectors to the new, i.e. ##e_i'=Ue_i##. I'll start by proving that this U must be unitary (assuming that both bases are orthonormal). For all i,j, we have
$$\langle e_i,e_j\rangle =\delta_{ij}=\langle e_i',e_j'\rangle =\langle Ue_i,Ue_j\rangle =\langle e_i,U^\dagger U e_j\rangle,$$ and therefore
$$\langle e_i,(I-U^\dagger U)e_j\rangle =0.$$ This implies that for all j and all vectors x, we have
$$\langle x,(I-U^\dagger U)e_j\rangle =\left\langle\sum_{i=1}^2 x_i e_i,(I-U^\dagger U)e_j\right\rangle =\sum_{i=1}^2 (x_i)^* \langle e_i,(I-U^\dagger U)e_j\rangle =0.$$ In particular, this holds when ##x=(I-U^\dagger U)e_j##. That implies that for all j, we have ##(I-U^\dagger U)e_j=0##. This implies that ##U^\dagger U=I##.
Now if we define ##S=U^{-1}## and use that ##U^\dagger=U^{-1}##, we have
\begin{align}
H'_{ij}=\langle e_i',He_j'\rangle = \langle Ue_i,HUe_j\rangle =\langle e_i,U^\dagger HUe_j\rangle =(U^\dagger HU)_{ij} =(SHS^{-1})_{ij}
\end{align} In other words, the components of ##H## in the primed basis are the same as the components of ##SHS^{-1}## in the unprimed basis.
Likes aaaa202
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
