Change of Variable With Legendre Equation
Bassa
[/B]
Change the independent variable from x to θ by x=cosθ and show that the Legendre equation
(1-x^2)(d^2y/dx^2)-2x(dy/dx)+2y=0
becomes
(d^2/dθ^2)+cotθ(dy/dθ)+2y=0
2. Homework Equations
[/B]
I did get the exact form of what the equation should become, but I had a 2 in front of the cotθ term. I was wondering if the answer that the book provides is missing a factor of 2 in front of the cotθ term?
No, there shouldn't be a "2" factor there.
Thank you very much for your reply! I have spend many an hour trying to figure out where the 2 goes, but that was to to avail. I have the following:
(dy/dx)=(dy/dθ)(-1/sqrt (1-x^2))=(dy/dθ)(-1)(sin(θ))^(-1)
Can you please direct me to where I went wrong on the above statement?
Thanks!
The problem lies elsewhere. Show your calculation of ##(1-x^2)y''##.
Thanks for your reply! Here is my calculation for (1-x^2)y'':
(d^2y/dx^2) = (d^2y/dθ^2)(1-x^2)^(-1) = (d^2y/dθ^2)(1-(cosθ)^2)^(-1)
(1-x^2)y'' = (1-(cosθ)^2)(d^2y/dθ^2)(1-(cosθ)^2)^(-1) = (d^2y/dθ^2)
Differentiate the result you got for y'.
$$\frac{d^2}{dx^2}y = \frac{d}{dx} y' = -\csc\theta \frac{d}{d\theta} y' = -\csc\theta \frac{d}{d\theta} \left(-\csc\theta \frac{dy}{d\theta}\right)$$ You need to use the product rule.
I do have that in my solution and it leads to the earlier reply I posted. It also leads to the correct first term of the right answer. Is the following correct?
-csc(θ)(d/dθ)[y] = (cscθ)^2(d^2y/dθ^2)
No, that's not correct. As I noted earlier, you have to use the product rule. The ##d/d\theta## on the left acts on everything to its right.
Thank you very much! Sorry for the late reply, but I had to sleep on it. It worked perfectly fine! I was inventing my own incorrect rules for calculus, and that did not work very well!
P.S. I was wondering how you were able to type those derivatives very clearly. It is much more clear than having slashes and asterisks?
Thanks a lot!
