Changes of state and latent heat
To cool a 286 kg mass of alloy steel from 452 degrees C to 100 degrees C, a foundry operator needs to calculate the heat transfer involved. The operator initially calculated the heat lost by the steel as 45,503,744 J but did not account for the latent heat of vaporization when determining the mass of water required. The correct approach involves equating the heat lost by the steel to the heat gained by the water, which includes both the sensible heat and the latent heat during phase change. The operator's calculations resulted in a required mass of water of 139 kg, while the textbook states it should be 21.5 kg, indicating a misunderstanding of the latent heat concept. Incorporating the latent heat of vaporization is essential for accurate calculations in this scenario.
shannon.leigh
A foundry operator finds that it takes 55.6 MJ of heat to heat a 286 kg mass of an alloy steel from 22 degrees C to 452 degrees C. Specific heat capacity of the steel is 452J/kg/K.
If the foundry worker cools the steel by poring water onto it, the water will heat up to its boiling point, then it will boil. What minimum mass of water, initially at 22 degrees celcius, would cool the hot steel down to 100 degrees celcius?
I figured that
delta Q= delta T*c*m
and
delta Q=L(vaporisation)*m
would probably be relevant
I went. . .
delta Q(of steel) =delta T*m*c
=352*452*286
= 45503744 J therefore Delta Q(of water)= 45503744 J
Delta Q(of water)=delta T*m*c
m(of water)=Delta Q/(delta T*c)
=45503744/(78*420)
=139 kg
But the book said the mass of water was 21.5 kg. :S
I think I need to incorporate the Latent heat of vaporistion of water into this somewhere, but I am way to confused to work out how. . .
Any help would be soooo apreciated!
Thankyou!
Shannon
The Q leaving the steel must equal the Q entering the water. The water heats up, then changes phase. The heat necessary to change a certain mass of water from liquid to steam is your latent heat. Therefore, you're missing something in your delta q of water
thanks! big help :)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
