Changing order of integration problem
  • Thread starter Thread starter Chandasouk
    Integration
Chandasouk
http://img576.imageshack.us/f/64147491.jpg/
I understand how to obtain the new bounds when you change integration, I'm just having problems actually integrating. How did they rewrite the equation to that of step 2?
The inner integral is a dy integral of this form (because x is constant in the dy integral)
\int \frac a {(b+y)^\frac 1 2}\ dy
Let u = b + y, du = dy so it looks like
\int a(u)^{-\frac 1 2}\ du
and integrate it.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
