How Does Earthing Affect Charge Distribution on Spherical Shells?
The discussion revolves around the charge distribution on three concentric spherical shells, where shell B is earthed and shells A and C have charges q and -q, respectively. It is clarified that shell B, being grounded, can draw charges from the ground, allowing it to have a non-zero net charge despite initially having none. The inner surface of shell B acquires a charge of -q, while the outer surface has a charge q', leading to a corresponding charge distribution on shell C to maintain charge conservation. The conversation also emphasizes that while shell B is not isolated due to its grounding, shells A and C are isolated, allowing charge conservation to apply to them. Overall, the grounding of shell B complicates the application of charge conservation principles in this scenario.
gracy
I don't understand charge distribution properly.
Here is what I found somewhere
Figure (1)shows three concentric thin spherical shells A,B and C of radii a,b and c respectively.The shells A and C are given charges q and -q respectively and the shell B is earthed.Find the charge appearing on the surfaces of B and C.
Figure (2) shows how charge distribution would take place.
Charge distribution:The inner surface of B must have a charge -q from the Gauss's law.Suppose,the outer surface of B has a charge q'.The inner surface of C must have a charge -q' from the Gauss's law.As the net charge on C must be -q ,it's outer surface should have a charge q'-q.The charge distribution is shown in the figure.But as per my understanding
The inner surface of B must have a charge -q so that net charge becomes zero because as shell B is earthed it has to be at zero potential.But then we will be violating "conservation of charge"law.As originally shell B does not have any charge.That's why the outer surface of B should have charge q.
I am all confused about shell C.As according to Gauss's law it is ok to have charge q on the outer surface(i.e inside shell C) of B because this gives net charge q inside shell C and that was the case initially.But then total charge of shell C becomes zero and that violates "conservation of charge"law.
Please help.I am really Sorry if it is confusing.
Shell B is not isolated since it is connected to ground. Ground can be treated like a big neutral sea of available charges (positive or negative). If they can (if there's a conductive path) they will move to try to cancel charges and their fields.
So the charge conservation rule doesn't hold for shell B since it can draw on charges through its ground connection.
Did the problem source determine a value for the charge q' ?
Likes gracy
How can we determine if any shell is isolated?
No.
A body is isolated if it has no external connections that can conduct charges, that is, charges cannot leave or exit the object. Shell B is not isolated because it has a connection to ground by which charges can move onto or off of the shell.
Likes gracy
Can charge conservation be applied to shell C,I think yes.Because it seems isolated.
Yes. Both shells A and C are isolated so charge conservation holds for them.
Please help me to understand this.How and why?Any hint?
There can be no electric field inside a conductor, so something must prevent any field originating in the interior of shell C from penetrating shell C's material. If shell B has some charge q' on its surface, then that charge will attract its opposite charge -q' to the inner surface of C, satisfying the requirement of cancelling the field from B. That charge of -q must have come from the total charge q on the C shell (the C shell being isolated), leaving charge q-q' to present at the outer surface of C.
Likes gracy
But according to @nasu
nasu said:
If you put charge inside, the field does not have to be zero.
I believe that @nasu was referring to the field inside the cavity, not inside the shell conductor.
Likes gracy
Did you mean shell C by shell conductor?
gracy said:
If there is a charge inside the cavity of a non conducting shell,it is a trivial thing that the field is not zero.
Right?
nasu said:
This is true for conductive shell too.
But he did not mention cavity anywhere?Did he mean If you put charge inside the cavity of conducting shell,the field does not have to be zero.
Yes. If you put a charge in the cavity there will be a field in the cavity due to that charge.
Likes gracy
Please answer my post #13.
I wanted to distinguish the shell itself from the cavity that the shell surrounds. By shell conductor I mean the conductive material of the shell itself.
Likes gracy
If any conductive shell surrounds a hollow conductor,can that hollow conductor be treated as a cavity inside the conductive shell?
But the field would be zero inside the conductor surrounding that cavity?
I'm not sure that I understand what you're getting at. As far as I can tell you're describing nested conductive shells, or several hollow objects inside another shell. As you've seen, charges on nested shells can influence the field external to the outer shell. Any fields in the interior of that outer shell will be due to charges in its cavity, and they can interact between each other the way charges usually do. These charges can reside on hollow conductors.
Can you draw a scenario that might make your query more clear??
Likes gracy
Yes. The external field must stop at the surface of any conductor.
Likes gracy
What I am asking is, are these two same?
Well, the same in what way? In the diagram on the left one could place a charge on the inner conductor and there would be a field surrounding it in the open space between it and the outer shell. In the diagram on the right that space is filled with conductor (it's part of the shell) so there would be no field in that space, and there's no isolated conductor to hold a charge. In effect you have only one shell in the diagram on the right.
Likes gracy
Then where would the charge go if given ?I am referring to the cavity case.
But there is not any open space between it and the outer shell as far as I can see.
It would migrate through the conductive material to the surface of the shell. This is the basic premise where a charge placed on a conductive spherical shell resides at its surface.
Perhaps I am misreading your intentions with your diagrams? You don't indicate what's solid material and what is not. I interpreted your cases as follows:
Likes gracy
In the pictures you drew both inside and outside shells are hollow conductors,right?
White is empty space, color is conductor.
What I am asking is can that hollow conductor (hollow shell :shell containing cavity inside)be treated as a cavity inside the conductive shell?[/QUOTE]
  • #31
From post #9 I am quoting
But why is it needed?There is no charge inside the shell C in the first place i.e without this q' .So no field inside.
  • #32
[/QUOTE]
A "shell" is a single contiguous layer that encloses some space. It has two surfaces: an inside surface and an outside surface. I'm having trouble distinguishing a shell from your "hollow shell", since they should be identical, with the "hollow" being redundant. Two nested shells can have a hollow space between them. Perhaps that's what you mean?
In your drawing what I'm seeing is an outer shell (gold color) with a cavity, and in that cavity is another, single very thin shell represented by the line of a circle.
A shell can hold a charge, but a void (cavity) cannot. So in general a shell is not the same as a cavity.
Likes gracy
  • #33
gneill said:
A shell can hold a charge, but a void (cavity)can not.
So do you mean a cavity can have field inside it but it (cavity)can not have charge inside it.Because charge will migrate to the surface of conductor.Hence,charges migrate from cavity but field stays.
  • #34
Thanks for your patience @gneill.I am extremely sorry for my rapid questions.
  • #35
But why is it needed?There is no charge inside the shell C without this q' .
I can't tell you why it's needed since you haven't presented the rest of the context in which that diagram was found. For all I know they go on to prove that q' must have some particular value for the situation shown.
gracy said:
So do you mean a cavity can have field inside it but it (cavity)can not have not charge inside it.Because charge will migrate to the surface of conductor.Hence,charges migrate from cavity but field stays.
A cavity is empty space. Empty space can support fields. You can place charges (particles) inside a cavity and their fields will fill the cavity. But the cavity itself (empty space) cannot hold a charge. The best you can do is place things with charges in it, or try to place a charge on its boundary surface. But that boundary surface is part of a conductive shell, so they would be free to move away.
Likes gracy
  • #36
gneill said:
I can't tell you why it's needed since you haven't presented the rest of the context in which that diagram found.
Only this much information has been given.Figure (2) and charge distribution has been given as a hint.
  • #37
Closed pending moderation.
  • #38
Thread re-opened.
  • #39
I wonder why?
  • #40
ehild said:
I wonder why?
There was some concern that the thread was being spread into other threads with the conversations and results crossing each other. This makes following anyone thread a tad confusing, and moderating the ensemble somewhat problematic. Merging the threads was discussed, but it was decided that it would not give a satisfactory or more elegant result. So for now the thread is re-opened and any new fragmentation will be discouraged.
  • #41
From the OP:
The shells are thin, but still they have inner and outer surfaces. The shell makes a wall that surrounds the enclosed cavity. There is no charge, and the electric field is zero inside the wall, but there can be surface charge on both surfaces. The following is better for Fig. 2 as it was in the OP as it indicates that the charges belong to the surfaces.
Shell B was not given any charge, but it is grounded, the shell can have nonzero net charge.
Likes gracy
  • #42
Thank you gneill, for the explanation, and also for re-opening the thread.
Likes gracy
  • #43
But it is not compulsory that every earthed shell would have some non zero net charge.Why surface of shell B contain charges,what if the charges are not there?
  • #44
A single earthed shell is not charged, but B encloses a charged shell, and is surrounded by an other charged shell. If you derive the potential of all shells, you get how much charge B must have to be at zero potential.
  • #45
But I was not told to find potentials so I did not consider it ,I believe that's why I got stuck.
Does it mean whenever I will find such problem when there is not single earthed shell ,I'll assume some charge on it's surface later with the help of potentials ,I will find how much charge B must have to be at zero potential?
Right?
  • #46
What if the problem does not mention "thin",solution would be same?
  • #47
The problem asked you
, which means you need q' in terms of q. You should have figured out how to do it. You have to know, how to get the electric field of charged shells and potential difference between them, and how to get the potential of the outer shell C. Deriving the expresion for the potentials of the shells, you get an equation for q' in terms of q.
gracy said:
Does it mean whenever I will find such problem when there is not single earthed shell ,I'll assume some charge on it's surface later with the help of potential ,I will find how much charge B must have to be at zero potential?
Right?
Right. If a charged body is near an earthed conductor, the conductor gets charge from the earth.
Likes gracy
  • #48
Thin means the thickness of the shell is small with respect to the radius, so we can speak about "the radius of the shell". If they were not thin, the inner and outer surfaces would have different radii. Those radii should be given, and the solution would be different.
Likes gracy
  • #49
Will it be a problem?
  • #50
No problem, but you need to take them into account when calculating the potential of the shell.
Likes gracy
