Charge on terminals of a battery
In summary, the concept of Potential Difference (P.D) is the work done in moving a positive charge from a lower potential to a higher potential. However, when considering the flow of current due to negative charges (such as electrons), the concept of P.D is still applicable as it represents the work done per unit charge. This can be compared to the concept of gravitational potential, where an object with mass will travel "down" a gravitational potential difference. In the case of electric potential, positive charges will also travel "down" an electric potential difference in an electric field, similar to how water flows from high pressure to low pressure.
shehri
30
Hi all,
We consider +ve terminal of a battery as higher potential & -ve terminal as lower potential.The work done in moving a +ve charge from lower to higher potential is called Potential difference.But if the flow of current is due to electrons(-ve charges) then what'll be the concept of P.D(Potential ifference)?.
Negati...er, no, un-affirmative
the work done is just that. But that's a little abstract a concept, so we normally look at the work done per unit time, which is the power. So if you use joules for work and seconds for time, you get watts!
Edit: Well the work done per unit charge, that would be the voltage, wouldn't it? Meh something like that
Anyways, to actually answer the question, I think of an object with mass in a gravitational field and how it will travel "down" the gravitational potential. A difference in gravitational potential is easily visualizable as say...a hill!
in a similar fashion a positive electric charge in an electric field will travel "down" an electric potential difference(of course unlike mass and gravity there isn't a "negative" mass...that we've seen!)
if you want to use the water analogy, electric current is like, well, water current, and then high potential would be like high pressure and low voltage like low pressure
1. What is the charge on the terminals of a battery?
The charge on the terminals of a battery refers to the amount of electrical charge present at the positive and negative terminals of the battery. This charge is what drives the flow of electrons through a circuit.
2. How is the charge on the terminals of a battery determined?
The charge on the terminals of a battery is determined by the chemical reactions happening inside the battery. As the battery discharges, the chemicals inside react to produce a flow of electrons, creating a difference in charge between the positive and negative terminals.
3. What is the unit of measurement for charge on the terminals of a battery?
The unit of measurement for charge on the terminals of a battery is Coulombs (C). This unit is used to measure the amount of electric charge present at the terminals of the battery.
4. Can the charge on the terminals of a battery be positive or negative?
Yes, the charge on the terminals of a battery can be positive or negative. The positive terminal has a surplus of positive charge, while the negative terminal has a deficit of positive charge, resulting in a negative charge.
5. Is the charge on the terminals of a battery constant?
No, the charge on the terminals of a battery is not constant. It decreases as the battery discharges and the chemical reactions inside the battery slow down. The charge can also vary depending on the type and age of the battery, as well as the amount of current being drawn from it.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
