Can I Use a Different Charger for Xbox?
  • Thread starter Thread starter krak
    Charger
Using a different charger for an original Xbox can be risky, as the Xbox's power supply is internal, and it operates on 120VAC from the wall. While the voltage of the alternative charger falls within the acceptable range, the higher amp rating could lead to issues if the charger is not designed for low load conditions. It's recommended to test the voltage under load with a voltmeter to ensure it remains stable and within the Xbox's operating range. If the replacement cord is simply a power cord without a transformer, it may be safe to use. However, for optimal safety and performance, purchasing an OEM power supply is advised.
krak
Sorry if this question is really stupid. I tried to look for calculators but wanted to be sure. I have an original Xbox but no power cord for it, however I have an extra power cord for something else that fits perfectly. I want to know if I can safely use it.
Xbox: 100 V - 127 V ~ 2.1A
50/60 HZ
Charger: 10A 125V
The volts falls within the range of the Xbox range. Is a higher amp number on the charger okay though?
Thanks in advance
That's not always easy to say, because some supplies tend to "run away" when operate at low load conditions, or they may not be a type that regulates at all. The simplest solution is to purchase an OEM power supply, but I hate spending money on these things.
So, if I were in you're shoes, I'd take the ol' volt meter, a bit of wire, maybe some tape, and bring the connection out where you can measure it and put it under a bit of load. Just as a quick test, I'd load it with a small incandescent bulb, i.e. a 20 watt from the chandelier :~), then follow that with a large bulb, say a 100watt. If the voltage stayed within 1% or so and is within the operating range of the box (plus the connector polarity is correct!) then, I'd go for it.
Best of luck ( and please remember, I'm frugal, but not always sensible! )
Mike
I received a ping from another memeber noting that the Xbox has two supply voltages. In that case, this is a grossly oversimplified explanation. I'd probably stick with an original equipment replacement.
Mike
The original Xbox simply takes normal 120VAC from the wall; its power supply is inside the unit. The 360 has the power supply out side, as part of the cord (inline). If your replacement cord is just a simple cord meant for use in bringing 120VAC from the wall to a device then it should be fine. However, you mention a "charger". Can you explain more what you mean by this, or perhaps post a picture? Maybe it's from an inline power supply with a detachable cord, and you are reading the specifications from the power supply. If that is the case then it is fine to use the cord. There should be no transformer (powerbrick, wallwart, etc) between the wall and the Xbox.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
