Efficient Charging System Design Help for GTL ICR18650 Battery
The discussion focuses on designing an efficient charging system for a product utilizing the GTL ICR18650 3.7V 3000 mAh Lithium Battery. The Texas Instruments LM2623 boost converter is proposed to step-up voltage and regulate amperage for charging and powering the device, with participants expressing support for this choice. There is a request for suggestions on cost-effective chargers suitable for the device. A specific charger linked in the discussion is mentioned as potentially fitting the project's needs. Overall, the conversation emphasizes the importance of selecting the right components for effective power management in the product design.
InventorShawn
I am redeveloping a product that literally billions of people use, from every day to at least once a month. I need some help designing the power portion, as I am not an engineer.
I am planning on using the GTL ICR18650 3.7V 3000 mAh Lithium Battery because it provides the power needed, as well as cost efficiency. Now to charge this battery as well as to power this device using lower power than the battery (ie. solar panel) I found the Texas Instruments LM2623 boost converter to step-up the voltage and regulate the amperage. Would this work?
I am also having troubles finding a charger for this device. Could anyone suggest any that are well suited and cost effective?
Also, your choice of the LM2623 seems perfect for this application!
Thank you! Sorry, thought my reply posted.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
