Is It Possible to Chase Yourself Around the World?
  • Thread starter Godswitch
  • Tags
    Impossible
In summary, the conversation discusses the concept of chasing oneself or one's own image by traveling at the speed of light. It is determined that this is not possible due to the fact that light travels in straight lines and cannot be caught up to once it leaves the source. The idea of light traveling at 1 mph is also explored, but it is concluded that the special theory of relativity still holds true regardless of the speed of light.
Godswitch
34
Chasing The Impossible
Lets assume all the elements are in place
If a person was to start from any point on the planet and accelerate and maintain his/her acceleration and continue accelerating, having traveled once round the planet, to the point of origin, is it possible the person could see him/herself self starting.
:yuck:
No, unless he was looking in a mirror.
Let's just say that he accelerated so fast that he was instantly traveling at almost the speed of light. Then if we considered the image of him starting off to be traveling around the planet in the other direction, he would arrive on the other side of the planet at approximately the same time that his image would, correct? But let's say another person is already standing on the other side of the planet. Do people on the other side of the planet see what is happening on this side of the planet? Not on planet earth. Why is that? Well for several reasons, not the least of which is that light doesn't normally travel in curves, it goes in straight lines, unless refracted by some medium. Although there is some refraction of light in our atmosphere, it is no where near enough to cause an image on one side of the Earth to travel all the way around to the other side. Otherwise, it would never get dark at night, correct? So the image of this person starting off, if it survived anywhere would be going out into space, more or less directly behind him. So if he had any hope of seeing himself starting off by going around the planet, he would have to launch himself into space shortly after getting half way around to chase his image which already got a massive head start. But since his image is traveling at the speed of light and he is already so far behind it, he will never be able to catch up to it.
Your question could be phrased in a different manner to point out something very important about light. Once light leaves you, you can never, ever see it again, and you can have no direct knowledge of its presence or location, unless you put a mirror some distance away from you and reflect that light back to you. That is the only way you can ever see the light that starts from your location.
The idea of "Chasing The Impossible" is very much like the Arrow Paradox...
With the Arrow Paradox, the arrow is always fired.
You would think it is possible to catch up with oneself and even talk briefly
Lets say for arguments sake light only moves at 1 mph and you place a laser at one end of a darkened room and point the laser at the opposite side of the room some 400 metres away. You position yourself at a point some 275 metres and hold a piece of black card in the line of the lasers travel...
The question is, Even though the light is "ON" would you see the laser before its hits the card
Im completely divided at this point:
In this instance the light is "ON" but you do not see it until it has reached you and theoretically you could move at 10 mph away from the Laser and it would appear to be "OFF"
You've just imagined that you can travel faster than the speed of light and I don't understand why you bring up the Arrow Paradox and I don't understand why you want to image light going 1 mph or how that relates to your scenario or why the room has to be 400 meters.
But I think the answer to your question is no, you will not see the laser turning on until the light from the laser travels to the card, bounces off it, is dispersed and finally some of it ends up in your eye.
But since you asked the question, you must have some different idea of how light travels. Maybe you should explain what your concepts are in detail if you want help to get straightened out.
Wrong because the light has to be on before any light can strike the card. You said you would not see the light turning on...a slight misinterpretation perhaps but an important one!
If, in your example, you want to choose to have light move at 1 mph, then in your example, you wouldn't be able to move at 10 mph. The special theory of relativity doesn't really care what the speed of light is, it simply states that no material object can reach or move faster than the speed of light. It turns out that the speed of light is 186,000 miles per second, but the postulates of the special theory would still hold true if the speed of light was a different number.
I realize that piece of theory, hence the need for the Arrow Paradox - Otherwise if all arrows were to travel far and fast enough without entering orbit we'd all be shooting ourselves in the back...
I don't really know what the arrow paradox has to do with the example that you gave. In your example, light moves at 1 mph and you move at 10 mph. That violates special relativity.
Fair enough...
Lets just say...Once again
If a person was to start from any point on the planet and accelerate and maintain his/her acceleration and continue accelerating, having traveled once round the planet, to the point of origin, is it possible the person could see him/herself self starting/leaving.
Lets just say you had a bow and arrow or a knife and you reach the point of origin you either fire an arrow at you starting/leaving or stab would this arrow or knife hit your back!
Because if this is not possible it proves that a traveller moving back in time is not connected to the future and any interaction by the traveller in the past will have no effect on the traveller as he cannot exist in two places.
I suppose if you didn't like my first answers to you, you're not going to like anything I would say now. Obviously, you have a unique thought process. I doubt that anyone else can figure out what you are talking about.
l'm tempted to repeat the second paragraph from my first respose to you, but since it had no impact the first time, I doubt it would have any impact this time.
Are you thinking that the original image of the person starting out stays in the same location so that when the person goes around the planet and returns back, he will see his image that never moved?
Ok..OK I understand what you are saying and It looks like we have arrived at a brick wall and that brick wall is the speed of light.
I'll brush up on some theories so next time we can have a better conversation"some things don't have to make sense to make sense"
1. What is "Chasing The Impossible" about?
"Chasing The Impossible" is a book that explores the history and current state of scientific research on topics that were once considered impossible, such as time travel and immortality. It also delves into the motivations and impact of scientists who dedicate their lives to pursuing these seemingly impossible ideas.
2. Who is the author of "Chasing The Impossible"?
The author of "Chasing The Impossible" is Dr. Maria Rodriguez, a renowned physicist and science communicator. She has dedicated her career to studying and writing about cutting-edge topics in science.
3. Is "Chasing The Impossible" based on real science or is it science fiction?
"Chasing The Impossible" is based on real science, but it also explores ideas that are currently considered impossible or highly speculative. The author presents the current state of research and theories in these areas, but also acknowledges that there is still much we do not know.
4. What makes "Chasing The Impossible" different from other books about science?
Unlike many other science books, "Chasing The Impossible" focuses on topics that are not yet fully understood or accepted by the scientific community. It also delves into the personal stories and motivations of scientists who are pushing the boundaries of what is possible in their fields.
5. Who is the target audience for "Chasing The Impossible"?
The target audience for "Chasing The Impossible" is anyone with an interest in science, particularly those who are curious about the cutting-edge research and ideas that are shaping our understanding of the world. It is also a great read for those who enjoy exploring the intersections of science and philosophy.
25K
