Calculate Meeting Time for Equilateral Triangle Turtles | Classic Problem Solved
  • Thread starter Thread starter jpas
The discussion revolves around calculating the meeting time for turtles positioned at the vertices of an equilateral triangle, each moving towards the next. The initial incorrect calculation suggested a meeting time of L/3V, but it was corrected to 2L/3V, indicating that the turtles take longer to converge than initially thought. The conversation highlights the importance of understanding the geometric relationships and motion dynamics involved, particularly the radial distance and angle of movement. A key insight is that the turtles' paths create a continuously changing equilateral triangle, complicating the calculations. The problem is noted as a fun and engaging challenge for those interested in geometry and motion.
jpas
This is supost to be a classic. I solved it but my answer isn´t right and I can´t find out why. Hope you guys can help.
Imagine an equilateral triangle with one turtle on each side of lenth L. All turtles move with velocity V. Turtle 1 always directs its motion to turtle 2, turtle 2 to turtle 3, and turtle 3 to turtle 1, again. Calculate the time the turtles take to meet.
The movement will be something like this.
Relative to turtle 2, turtle 1 will be in uniform rectilinear motion and its velocity will be:
\vec V_{12}=\vec v_1 - \vec v_2
\vec v_1 and \vec -v_2 make an angle of 60º degrees. So,
V_{12}= \frac{V}{\sqrt{3}}
Relative to turtle 2, turtle 1 will only travel the distance that separates it from the center of the triangle, which is \frac{L}{3}
So, t= \frac{v_{12}}{d} = \frac{L}{3V}
P.S.: I guess some of you might have already solved this problem. If not, I recommend it, though I got it wrong.
You have an equilateral triangle with side length L. The velocity of each turtle is v. The triangle defined by the 3 points (turtles) is always at any time t an equilateral triangle. Because the distance d between the turtles (the side of the equilateral triangle) at time t is
d=L-vt,
the turtles meet when
L-vt = 0
Bob S
Thanks for the answer.
d=L-vt,
This isn´t true. How did you arrive to this equation?
The real time the turtles take is \frac{2L}{3V} , 1.5 times what you got.
Does anyone have other sugestions? I advise you, if you´ve got nothing to do, this is a fun problem!
You are correct. The easiest way to get the solution is to use radial coordinates. The direct distance from the apex to the center is (from plane geometry)
R = L/√3
For a radial step dr, the turtle must always travel a distance 2·v·dt/√3
So to travel a radial distance R=L/√3,
v·t = (L/√3)(2/√3) = 2L/3
t=2L/3v
Bob S
Hi Bob, thanks for the reply.
R = L/√3
Right. On my orginal post I had a typo. I meant this.
Can you explain this step? What is dr and how did you calculate it?
For a radial step dr, the turtle must always travel a distance 2·v·dt/√3.
A turtle step dx = v·dt is always at a 30-degree angle to the radial direction dr from the apex of the equilateral triangle (between the 3 turtles) to the center, because the radial direction always bisects the 60-degree angle of the equilateral triangle (even as the turtles move and the equilateral triangle rotates), and the instantaneous direction of v·dt is always parallel to one of the sides of the equilateral triangle. Using plane geometry, the longer side of a 30-60-90 degree triangle is equal to √3/2 times the hypotenuse. The turtle step v·dt is along the hypotenuse and the radial step projection dr is along the longer side.
So a radial step dr = (√3)·v·dt/2
Bob S
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
