Chebshev polynomial approximation
sbashrawi
Hi every body
I am triyng to find a polynolial approximation to the function: f(x)= (x+2)ln(x+2)
using the chebyshev polynomials,
the idea is to use MATLAB to find the coeefficients of the approximation poly.
using the comand double(int(...))
but this command doesn't give me any numerical value
Waht I got was:
>> int((x+2)*log(x+2)*(1-x^2)^-0.5,-1,1)
Warning: Explicit integral could not be found.
ans =
int((log(x + 2)*(x + 2))/(1 - x^2)^(1/2), x = -1..1)
and if I use double(int(...)) an error message shows up
Any help pls
Consider the substitution x=\cos(\theta) and note that T_k(x) = \cos(k \,\theta). This should remove the singularity.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
