Calculating Final Temperature of Steam and Water Mixture - Chemistry Question
  • Thread starter Thread starter GodsChild086
    Chem Energy
The discussion revolves around calculating the final temperature of a mixture of steam and water. The initial problem involves mixing 50.0 g of steam at 100 degrees Celsius with 600 mL of water at 10.0 degrees Celsius, with the expected final temperature being 58.3 degrees Celsius. Participants clarify that after steam condenses, it becomes water, which should be factored into the heat transfer calculations. The original poster realizes their mistake in using the specific heat capacity of steam instead of water after the phase change, leading to the correct answer. A follow-up question about mixing ice and steam indicates ongoing challenges with similar thermodynamic calculations.
GodsChild086
I'm really stuck on this question:
What will be the final temperature if 50.0 g of steam at 100 degrees celsius is mixed with 600 mL of water at 10.0 degrees celsius? (Answer: 58.3 degrees celsius)
So far I've got:
heat lost (steam) = heat gained (water)
nH + mc(delta)t = mc(delta)t
Sorry I don't know how to make the delta symbol.
(500g/18.02g/mol)(40.65 kJ/mol) + 0.500 kg(2.02 kJ/kg*C)(100-t) = 0.600 kg(4.19 kJ/kg*C)(t-10)
When I calculated everything, I didnt' get 58.3*C, so maybe someone can tell me where I went wrong in either my formulas or calculations. Thanks.
You used the specific heat capacity of steam, but after the phase change, it is water that is being cooled and no longer steam.
Try to assume that all the steam became liquid water after mixing with water.
If the value of temperature is above 100, then there are some steams left.
I got the answer now...I forgot that after when steam goes through a phase change, it is now water, not steam. Now my answer matches in one in the book. Thank you!
This is the question that I'm actually really having trouble cause I don't have a clue where to start. I think this is one of those really nasty questions.
Calculate the final temperature when 100 g of ice at -10.0*C are added to 30.0 g of steam at 110*C.
I actually sort of know where to start...but yeah, I'm very stuck on this one...
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
