Jurrasic
- 98
Calculate, (in J) the change in internal energy for a balloon that is heated by adding 215 cal of heat.?
It expands doing 422 J of work on the atmosphere?
convert everything to J, and use the formula for change in energy:
Energy final - Energy initial
(only problem is if you use that you set it up this way: -422J - (+899.56 J) and that would give a wrong answer wouldn't it?
Because 425 was released and 899.56 was absorbed? So using the equation makes it wrong? You shouldn't subtract your initial energy if it is absorbed, but the equation says to subtract the initial energy? So how do you do this? )
Is 477.56 the correct answer?
