Christoffel Symbols of Vectors and One-Forms in say Polar Coordinates
The discussion revolves around the Christoffel symbols in polar coordinates, specifically whether they are the same for vectors and one-forms. Participants explore the implications of these symbols when calculating covariant derivatives for both types of mathematical objects.
  • Some participants question whether the Christoffel symbols should be the same for vectors and one-forms in polar coordinates, noting discrepancies when calculated using different basis vectors.
  • One participant suggests that while the Christoffel symbols may be the same, the equations for the covariant derivatives differ in sign depending on whether they are applied to vectors or one-forms.
  • Another participant proposes that the calculations being performed might actually be for Ricci rotation coefficients, which are antisymmetric in the lower indices.
  • A later reply emphasizes the need for proper notation when expressing the covariant derivative of basis vectors, suggesting a specific form for clarity.
Participants express differing views on the relationship between the Christoffel symbols for vectors and one-forms, with no consensus reached on whether they are the same or different. The discussion remains unresolved with competing interpretations of the mathematical relationships involved.
Participants note potential confusion arising from notation and the specific definitions of the mathematical objects involved, which may affect the interpretation of the Christoffel symbols and their application in covariant derivatives.
Skhaaan
Hello all,
I've been going through Bernard Schutz's A First Course In General Relativity, On Chapter 5 questions atm.
Should the Christoffel Symbols for a coordinate system (say polar) be the same for vectors and one-forms in that coordinate system?
I would have thought yes, but If you calculate the Christoffel Symbols using the Basis vectors of basis one forms then you get different Christoffel symbols?
I am asking because when you do the Covariant Derivative of a vector or a one form are the Christoffel Symbols the same of different?
For Vectors i.e.
\vec{V} = v^{\alpha}\vec{e}_{\alpha}
We can calculate the Christoffel symbols using
\frac{∂ \vec{e}_{\alpha}}{∂x^{\beta}} = \Gamma^{\mu}_{\alpha \beta} \vec{e}_{\mu}
Where the Basis vectors for polar coordinates are
\vec{e}_{r} = Cos(\theta)\vec{e}_{x} + Sin(\theta)\vec{e}_{y}
\vec{e}_{\theta} = -r Sin(\theta)\vec{e}_{x} + r Cos(\theta)\vec{e}_{y}
For One-Forms i.e.
\tilde{P} = p_{\alpha}\tilde{e}^{\alpha}
\frac{∂ \tilde{e}^{\alpha}}{∂x^{\beta}} = \Gamma^{\alpha}_{\beta \mu} \tilde{e}^{\mu}
\tilde{e}^{r} = Cos(\theta)\tilde{e}^{x} + Sin(\theta)\tilde{e}^{y}
\tilde{e}^{\theta} = - \frac{Sin(\theta)}{r}\tilde{e}^{x} + \frac{Cos(\theta)}{r}\tilde{e}^{y}
Skhaaan said:
Hello all,
One minor appearance tip. To make the Christoffel symbols vertical alignment proper, the latex looks llike this: \Gamma^{\alpha}{}_{\beta\mu}, i.e. \Gamma^{\alpha}{}_{\beta\mu}. The extra empty {} at the end does the trick.
The Christoffel symbols are the same, but the equation for incorporating them into the covariant derivative changes sign depending on whether you are taking the covariant derivative of a vector or a one-form.
I'm having a bit of trouble following your notation, the way I"m used to writing this is:
eq1 \nabla_a t^b = \partial_a t^b + \Gamma^{b}{}_{ac} t^c
eq2 \nabla_a \omega_b = \partial_a \omega_b - \Gamma^{c}{}_{ab}\omega_c
where eq1 represents taking the covariant derivative of a vector t^b, and eq2 represents takig the covariant derivative of a one form \omega_b.
In the above notation \partial_a represents an ordinary derivative, i.e \frac{\partial}{\partial a}
\nabla_a represents the corresponding covariant derivative. Thus eq1 and eq2 tell you how to construct the covariant derivative out of the ordinary derivative in some coordinate basis and the Christoffel symbols.
It looks to me like what the OP is calculating are the Ricci rotation coefficients. They are antisymmetric in the two lower indices rather than symmetric.
Hey Guys, thanks a lot for replying
Thanks for the tip with arranging the indices using latex.
After some thought I think I have figured out what I was asking
Cheers guys
Shouldn't these equations in the OP read
<br /> \nabla_{\mu} e_{(\nu)} \equiv \Gamma_{\mu\nu}^{\rho} e_{(\rho)}<br />
stating that the covariant derivative on basis vectors e are linear sums of basis vectors? See e.g. Nakahara.
  • · Replies 19 ·
