Circle easy question,
  • Thread starter macarino
  • Tags
    Circle
:frown:1. I have a circle equation
[tex](x+a)^2+(y+b)^2=r^2[/tex]
And suppose we start from the topmost of the circle
2.I have an angle Theta
and if Theta is larger than 0 we move counterclockwise or we will move in the opposite direction if it is positive.
, how can I find out the coordinates of a point on the circle after the move
Thanks a lot :)
Answers and Replies
You mean "negative" instead of this second "positive" don't you?
Thanks a lot :)
For [itex]\theta[/itex] between 0 and [itex]\pi/2[/itex], at least, You can construct a right triangle by drawing a line from (0,0) to the point and then from the point perpendicular to the right angle. The y-coordinate of the point is the "near side", the x-coordinate is the negative of the "opposite side".
I am sorry I am not a native, not understanding what you mean
In the picture below, I'd like to know what is P's coordinates given rotation angle alpha and a point O(0,a)
The circle equation is
(x+a)^2+(y+b)^2=r^2
Thanks
Regards
You are taking [itex]\theta[/itex] to be 0 at the "top", (a,b+ r) and measuring it clockwise? If you were using the "standard", [itex]\theta= 0[/itex] to the right, (a+r, 0), and measuring counter clockwise, then you could use the parametric equations, [itex]x= r cos(\theta)+ a[/itex], [itex]y= r sin(\theta)+ b[/itex]. The fact that you starting 90 degrees off that means you need to swap sine and cosine: [itex]x= r sin(\theta)+ a[/itex] and [itex]y= r cos(\theta)+ a[/itex]. Now, taking [itex]\theta= 0[/itex] you can see that [itex]x= r(0)+ a= a[/itex], [itex]y= r(1)+ b= b+ r[/itex] as you want. Further taking [itex]\theta= \pi/2[/itex], we have [itex]x= r(1)+ a= a+ r[/itex], [itex]y= r(0)+ b= b[/itex] as wanted.
[itex]x= r sin(\theta)+ a[/itex], [itex]y= r cos(\theta)+ b[/itex].
