AlchemistK said:
Can the power supply in our house also be treated like a battery?
Then we shouldn't get a shock if we put one finger in the live wire socket until we put another finger in the neutral wire socket?
AC voltages, if we ignore induction, radiation, capacitive coupling, etc., will behave
exactly the same way as this battery we've been talking about. If you "freeze" any instant in time, we can analyze it in the exact same way as we do a battery... The difference is that the voltage potential is constantly changing magnitude and polarity, so to discuss it in terms of a circuit you need to kind of "freeze" it first. But it behaves the same way
And you need to be careful about sticking your finger in the live wire socket because in residential power distribution, we "ground" the neutral wire... this means that the ground you are standing on is already connected to the neutral wire back at the box. But what you're thinking is exactly correct. If we didn't "ground" the neutral back at your service entrance, you could stand there and hold on to the live wire all day standing in a puddle barefoot and you would not get shocked. The only reason current will travel through you at your house (and the reason
you should NOT do this) is because they intentionally connected the neutral to the ground. You would complete the circuit back to the source through the ground because they set it up that way.
All that being said... I've done this myself and nothing happens. The resistance of your body and the ground is so high that it is essentially an open. I don't recommend doing it just because you never know how resistive your body is and how close you are to the ground rod... plus if you're dealing with higher voltages, this could be extremely dangerous. My experience was with 120V. Too many variables, so nobody should be doing it.
You could kill yourself so don't try it!
RedX said:
The power supply can continuously push current through you. The battery won't push more current through you until you can get rid of the charges on the other lead of the battery.
both sources would continue to push current through you... this is ohm's law. it comes down to the available voltage and it's ability to "push" the current through the high resistance of your body. The battery, however, would drain very quickly compared to the AC power source at your house.
RedX said:
My guess is you'll probably die if you stick your finger in the live wire socket, although I'm not completely sure since if the socket has a ground fault interrupter, wouldn't it trip?
Also, what would happen if the neutral wire weren't grounded/earthed? Then would you die if you touch the neutral wire? What if the neutral wire were only connected to the transformer and there was no connection between the neutral wire and the ground?
If we didn't ground anything, then you could touch the neutral all day without danger. You caould also touch the "hot" or "live wire" all day without any danger. You aren't completing the circuit. As I explained above... the only danger we have messing around with power lines at our house is due to the fact that we intentionally "ground" the neutral wire at just about every power pole (in the US anyway) in the country and again at every service entrance to every house. There is a good reason for this that could take up an entire new thread, but for the sake of this conversation, the ground is completing the circuit (EDIT FOR CLARIFICATION: when you touch a powerline at your house, not under normal operating conditions) because the power company intentionally designed the distribution system that way.
