What is the signal flow in this circuit diagram?
  • Thread starter Thread starter propeller
    Circuit Diagram
The discussion centers on understanding the signal flow in a circuit diagram for a drum machine called the Bleep Drum. The user seeks clarity on how the signal moves through various components, including the Arduino microcontroller and other parts like resistors and capacitors. Participants emphasize the importance of consulting the microcontroller's datasheet for detailed information and suggest that the programmed code within the microcontroller generates sound, while components like resistors and capacitors regulate and modify the signal. The conversation highlights the significance of proper labeling in schematics for clarity. Overall, the focus is on explaining the basic signal path from the microcontroller to the output jack.
propeller
Hey guys I am having trouble understanding this circuit. Can someone help me get through it, and explain to me what the signal is doing form start to end please?
Uh ... you want to maybe throw out a hint or two? Like, where did you get it, what is it supposed to be for, stuff like that ... you know ... REALLY basic information!
right.. I am working on this memoir and don't know where to put my head anymore, sorry about that. I am working on a memoir in which I am talking about the Drum Machine! So i did all the history, the protagonist brands on the market today, and i thought it will be a good idea to build my own drum machine. looked on the internet for some ideas and found the Bleep Drum by Dr. Bleep. Great! so i bought one, built one with the easy instructions they have on there website, but i really want to explain in my memoire how everything works. So this diagram was downloaded straight from his website, and I let myself wrote what i knew, what i didnt...etc
Here is a list of the bleep drum's components: 1x Cicruit imprimé sur carte
1x Arduino Atmega328P chip
1x MCP4901 IC chip
1x Prise DIP 28 broches
1x Prise DIP 8 broches
1x Resonator de 16MHz
1x Transistor 78I05
2x Potentiometre 10K
4x Boutons 12mm Bleu, Rouge, Jaune et Vert
4x Boutons 6mm noir
1x Capacitor 10uF
2x capacitor 220uF
5x Resistor 1k
1x RGB LED
1x Jack stéréo (1/8)
1x interupteur SPDT
1x Batterie 9V
Better picture
Here is a better picture
1x MCP4901 IC chip
1x Transistor 78I05
4x Boutons 6mm noir
1x Capacitor 10uF
2x capacitor 220uF
5x Resistor 1k
1x RGB LED
1x interupteur SPDT
1x Batterie 9V
What is your circuit/electronics background? Have you read the datasheet for that microcontroller (uC)?
there are no datasheet but here is the background:
That's the component placement drawing.
And of course there is a datasheet. Just look it up on the web and download it to your PC to read.
What is a datasheet exactly? Do you mean the legend for the symbols?
No, a datasheet is published by the uC supplier. In the case of Arduino uCs, that supplier company is Arduino:
http://arduino.cc/en/Main/Products
You should download the datasheet for the chip, to learn more about how it is used.
thank you for that, but this is datasheet is going way to profound, I really would like to know how basically the signal goes from a component to another and how is it affected by each of the components presented on the diagram. The chips are basically filters with programmed code inside in which the signal goes through right?
what I am understanding here is that the programmed code is the source of the sounds produced by the tactiles? so the resistors are used here more as regulators, whereas the two capacitor modifies the pitch and adds distortion (two codes included in the micro chip), tactiles would be switches, each letting the signal to interract with the sound connected to them
When you write about components in a schematic, it's good practice to remember to include their names, i.e. 'R1', 'C1' etc.
I guess you're talking about the signal path from the microcontroller to the jack output?
All the magic happens in the microcontroller itself. R3 and R4 is just a voltage divider to drop the level and C1 AC-couples the signal to block any DC component. The microcontroller feeds this passive network through a digital-to-analog converter, which is controlled using a SPI-bus.
That is it! thank for your quick answers
