Engineering Circuit Element Question using Kirchoff's law
The discussion revolves around applying Kirchhoff's laws to analyze a circuit and calculate power delivered and absorbed. The initial calculations for part a are confirmed correct, with current values of 5A and 2A, and a voltage of 80V. However, part b reveals a discrepancy where the power delivered (P_d) does not equal the power absorbed (P_a), leading to confusion about the role of the dependent voltage source. Clarification is sought on how to determine if the source is absorbing or delivering power, with a suggestion that current direction relative to terminals indicates power flow. The final conclusion suggests that a current balance can help ascertain the correct values for the circuit analysis.
Paymemoney
[PLAIN]http://img137.imageshack.us/img137/355/circuit2.png
P=VI
P=I^2 R
V=IR
The part a is all correct.
i_\wedge = 5A
i_o = 2A
v_o = 80V
This is what i have done in part b but it is not correct because P_delivered not equal to P_absorbed.
P_d = (50*7)+(20*40)
P_d = 1150W
P_a = (5^2*18)+(2^2*40)+(8*5)(20)
P_a = 1410W
I am not sure if the dependent voltage source is power absorbed or delivered.
Can somebody explain to me what have they done in the part b answers. For instance how did they get the values for i_g?
[PLAIN]http://img257.imageshack.us/img257/6798/circuit2answer.png
P.S
I think you have mixed up which elements are absorbing power and which are delivering. The way i have always though about it (not that i need to think about it often, being a chemical engineering major haha) is that when current enters the positive terminal and leaves the negative terminal of an element, the element is absorbing power (and vice versa). Doing this gave me an answer of 4230W being absorbed and delivered in total.
It looks to me that ig is obtained by a current balance.
