Circuit/Magnetic Field: Find EMF Induced
  • Thread starter Thread starter bsmack
    Field
5 replies · 6K views
bsmack
A bar of length 22 cm that slides on two rails are connected together to make a complete electrical circuit. A magnetic field of strength 0.05 T directed out of the paper exists throughout the regions of space in which this machine is located. Assume that the distance between the rails l=20 cm and that initiaully the bar's sliding velocity is v=12 cm/s. Find the magnitude of the emf induced in this circuit.
What equations should I be looking at? If it's an equation involving an integral, please give the final equation and possibly an explanation.
The only equation I have available to me is emf = integ(E * dl). I don't know how I would get the electric field with the variables given, and I also don't know how I would get dl, as I don't think the length of the rails is given, just the length of the bar going across the rails and the distance between the rails.
use the universal flux rule.
emf = d(phi)/dt = B da/dt = Bl dx/dt = B v
So, my answer should be B*v=0.006 V? This is from a practice final, and the answer listed is 0.0012 V. Did we forget to multiply by 2 somewhere?
Check your units, bsmack. Does B v have the units of time derivative of flux? You see there is a slight typo in estel's final line. It should read [tex]B L v[/tex]. What is the value of L for your system? (Make sure you pick the right one!)
I think I figured it out. It should be emf = Bvl, correct?
