Circuit to control the pulse width of digital signals
The discussion revolves around circuits designed to control the pulse widths of digital signals, particularly focusing on how to map an input pulse width to an output pulse width through various functions. Participants explore different circuit designs, including one-shots and integrators, and their applications in generating specific pulse width transformations.
  • Some participants identify circuits known as one-shots or monostable multivibrators for generating fixed pulse widths, questioning their applicability for variable functions like y = f(x) = 2x.
  • One participant proposes a circuit involving an integrator and a comparator to achieve the desired output pulse width transformation.
  • There is a suggestion that cascading integrators could create a function proportional to x^2, though this raises concerns about the strain on analog circuits.
  • Another participant expresses uncertainty about whether the proposed integrator circuit can maintain a constant amplitude while varying the pulse width.
  • Some participants discuss the implications of using comparators to adjust output thresholds, with differing opinions on whether this approach will yield linear or nonlinear results.
  • There is a debate about the mathematical interpretation of integrating pulse widths versus multiplying them, with conflicting views on the outcomes of such operations.
Participants do not reach a consensus on the effectiveness of the proposed circuits or the mathematical principles involved. Multiple competing views remain regarding the functionality of integrators, comparators, and the nature of the output pulse widths.
Some participants mention limitations related to the performance of analog circuits, including potential issues with amplitude handling and the speed of response. There are also unresolved questions about the specific configurations of circuits and their implications for achieving desired pulse width transformations.
  • #61
ok cool!
just a note as dw changes the actual m value will change, this is due to the electronics. remember gain is defined as output over input, so as dw increases, your output will decrease and input stay the same, so your gain will go down. this is why the comparator ground is set at zero or close to it, so dw is zero or close to it.
also if you have to do anything complicated digital is the way to go!11
  • #62
I don't know how to do f(something arbitrary?) for a single pulse
but your discussion reminds me of old time-division analog computers from 1950's
where we generated a train of pulses with duty cycle proportional to some function of analog inputs.
We used them to multiply and divide analog DC voltages.
A pulse train has average value of area under the curve, (duty cycle) X height.
For example, a 0 to 10 volt square wave that's high half the time will have average value 5 volts.
So consider the following circuit, with following prerequisites:
Capacitor C is charged by E1 through R when S1 is up
and is discharged by -E2 through equal R when S1 is down
Frequency of switching is fast compared to time constant RC.
PWM is basically a zero comparator controlling ratio of switch S1's up and down times,
so as to maintain zero volts on capacitor C. Therefore Ecap remains very nearly zero.
(In the 1950's precise zero detectors were fairly easy but precision opamps were difficult.)Let fraction of time S1 is UP = DC for Duty Cycle
and fraction of time S1 is DOWN = (1-DC)
So current into C is E1/R X DC
and current out of C is -E2/R X(1-DC) which equals E2/R X (DC-1)
It is apparent that to maintain Ecap = zero, the charge and discharge currents must be equal
so E1/R X DC = -E2/R X (1-DC)
E1 X DC = E2 X (DC-1)
E1/E2 = 1 - 1/DC
Output switch S2 will have same duty cycle
so Eout will have average value E3 X E1/E2
and a simple low pass filter at Eout will deliver a clean analog voltage equal to E3 X E1/E2.
Now we can use that analog computing element to derive products, quotients, squares and square roots as follows
BIG TEN-OOPS HERE, good buddies...
delete the next image and use instead one following
my drafting mistake old jim
USE THIS IMAGE instead (i'd delete previous one but it's already been quoted)
Of course it's slow, two quadrants at best because E1 and E2 must have opposite polarity, and unstable at division by very near zero just like any divider.
but it's very handy for computing things like steam flow with density compensation from dp across an orifice as E1 and density (ρ of pressure) as E2, Eout tied back into E3 for square root of (dp X ρ) .
And absolutely impervious to Stuxnet.Hope you don't mind this digression.
But that's one way you could make pulses with ratio of ontime / offtime in proportion to f(?) = √(a product) which i think was an earlier question..
All we ever used was the analog voltages. This circuit is called "Time Division Multiplier" and is capable of extreme precision, for analog stuff. A testament to the tenacity of those 1950's circuit designers.
Modern ones use 555 timers and opamps and are still running in nuke plants. One even used a TL494 PWM.
old jim
ps it's late and something feels uncomfortable about my duty cycle derivation
will correct in the morning if needed...
  • #63
Digital is the way to go, I agree. But not clocked digital, as I want a continuous input output function
E1/E2 = 1 - 1/DC
old jim
Hi Jim,
Thanks for contributing to the conversation. I will look at your derivation some time today/this weekend. PWM is definitely something I have been looking into because it relates to my problem. The idea of having a single input pulse of width x and a single output pulse of y = f(x), for arbitrary x is a problem that I do not think anyone has solved in some general way. I imagine a lot of optics applications could use this. What do you think?
I can also imagine clocking the input pulse and doing some processing can give me an approximation, but this is not a continuous function and may have discretization issues for optical ranging, etc.
Lastly, if you have published any papers from the 1950's and onward, I would definitely like to take a look.
  • #64
wow jim that's awesome!
seth. what is the min pulse width you are expecting. in optical applications you can get pulses as short as ten picoseconds.
  • #65
Any range - ns,us, ms
  • #66
you should be able to capture anything down to hundreds or tens of ns easily. all you need is a frequency that matches the smallest pulse width you expect to receive. (ideally it would be much more)
  • #67
Drat today it's obvious why i was uncomfortable
stupid drafting error
second image should be replaced with this one:
i'll go back and add it to above post
apologies to you guys
the derivation is okay i think , but it's more obvious why it works if one used just up-time and down-time instead of duty cycle.
old jim
  • #68
Seth Cohen said:
Aren't one-shots and monostable multivibrators used for outputing pulses of fixed widths, so that the function above would be y = f(x) = c, where c is constant. What about something that doubles every input pulse width like y = f(x) = 2x?
Seth, I don't know if they can be called monostable or not, but circuits using the ubiquitous 555 chip in many of its disguises will output a pulse train of constant frequency but variable duty cycle (the fraction of the period of oscillation in which the pulse is "on"). Such circuits are called Pulse Width Modulators and are used to deliver controlled power at constant voltage and frequency to an external device. DC motor speeds and LED brightness can be controlled this way. If the frequency is high enough, the time constant of the external device smooths its input waveform. In the case of a motor, the inertia of the rotor carries it through the off periods of each cycle. In the case of LEDs, they are fast enough to flash on and off with each cycle, but our eyes have long time constants in their response to light, so they experience brighter or dimmer yet smooth light.
  • · Replies 32 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 19 ·
