Circuit to limit capacitor power draw
The discussion focuses on limiting the power draw from a 100,000 µF, 35 V capacitor to provide a regulated output voltage between 4V and 16V while delivering 300 mW to a 10-ohm load. The recommended solution is to utilize a Buck DC-DC converter, specifically the LT1933 Step-Down Switching Regulator, which can efficiently manage the varying voltage levels and current limits. The use of diodes for voltage drops was considered but deemed less efficient compared to a dedicated switching regulator. Additionally, LT provides a free SPICE simulation tool for circuit design.
  • Understanding of Buck DC-DC converters
  • Familiarity with capacitor specifications and behavior
  • Knowledge of voltage regulation techniques
  • Basic circuit design principles
  • Research the LT1933 Step-Down Switching Regulator specifications and applications
  • Learn about SPICE simulation for circuit design using LT's SwitcherCAD tool
  • Explore current limiting techniques in DC-DC converters
  • Investigate efficiency optimization strategies for power electronics
Electrical engineers, hobbyists designing power supply circuits, and anyone interested in optimizing capacitor discharge and voltage regulation in electronic applications.
capthook
Hello all!
Circuit to limit power draw from capacitor?
I want to limit my 100,000 uF 35 V capacitor that is charged (via schottky full-wave bridge) to between 4V to 16 V from dumping it's charge all at once.
I would like the capacitor to provide 300 mW to the load (10 ohm resistance). (ie. 1.25v @ .24A ) What do I need to do?
I could put diodes in between the capacitor and load for voltage drops - but the capacitors charge will vary from 4V to 16V..
I want to maximize efficiency.
Should I be looking at a switch mode DC/DC converter? Like this product?
LT1933 - 600mA, 500kHz Step-Down Switching Regulator in SOT-23
http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1042,C1032,C1064,P7531#featuresSection
Is this the type of circuit component I should be searching for to accomplish this?
Advice on implementing this?
I'm a bit over my head on this..
Thank you!
CH
capthook said:
Hello all!
Thank you!
CH
Yes, you should use a "Buck" DC-DC converter to make your regulated output voltage. The DC-DC can also supply the current limit function that you mention.
  • · Replies 17 ·
11K
