Engineering Circuit with Dependent Voltage source
The discussion revolves around solving for the current ix in a circuit with a dependent voltage source. The initial attempt involved applying Thevenin's Theory and using Kirchhoff's Voltage Law (KVL), but the poster got stuck on their calculations. A suggestion was made to divide the total current of 4A by 3, leading to an incorrect assumption about ix. Another participant proposed an alternative calculation, suggesting that ix could be derived from the difference between the currents in two loops, resulting in a significantly different value. The conversation highlights the complexities of applying circuit laws in the presence of dependent sources.
BBJ
Find ix
i tried answering it i wasn't able to get it. The answer is given for basis by the way. (ix = 1.176 A) The image is attached to this post. Sorry for the inconvenience, it's my first time to post here.
KCL(?)
KVL(?)
I am not really sure on how to tackle this problem. my professor said we could use Thevenin's Theory to get Ix. What i did was to make the independent current source open, then I was left with the circuit with the 2 resistors and the dependent voltage source. I used KVL giving me loop 1 and an equation 5I1 + 10I1 +2Ix = 0.. that's where i get stuck.. i don't know what to do next..
i hope someone can help me out! thank you very much!
In the circuit a current of 4A is given. Since there are two branches, and one branch has ix and the other has 2ix, the total current is 3ix. If 4A is divided by 3, then ix=4/3.
Are you sure that´s the right answer? Because if it is then KVL isn't true...
10(1.176)+5(2.824)-2(1.176) isn't equal to 0.
To me Ix = I1 - I2
I1 being th current around the first loop and I2 the current of the second loop.
That way Ix = -6.66666666666666666667 Amps and KVL stands.
  • · Replies 35 ·
  • · Replies 35 ·
  • · Replies 17 ·
