Power Analysis in Circuits: Understanding the Flow of Current
  • Thread starter Thread starter charlies1902
    Circuits Current
The discussion focuses on solving for V_out in a circuit using mesh analysis and exploring alternative methods like Kirchhoff's Laws and the Superposition Theorem. Participants verify calculations and confirm that V_out is indeed negative based on its configuration. The conversation also addresses how to determine the power produced by voltage sources, emphasizing that power is positive when current exits the positive terminal and negative when it enters. The importance of perspective in defining power as either generated or absorbed is highlighted. Overall, the thread provides insights into circuit analysis techniques and power calculations.
charlies1902
I attached the circuit. I'm trying to solve for V_out, but I'm stuck.
I can solve for it using mesh analysis, but there must be an easier way. I just don't see it yet. Can anyone give me a hint?
Use Kirchhoff's Laws.
I don't know that it's any easier than mesh analysis.
To me simplest seems using the Superposition Theorem.
I used mesh analysis. Can someone verify if my answer at the bottom is correct?
Here's what I did using mesh analysis:
1. For the 3 closed loops, assume each loop has a clockwise current
2. I1 is the left loop's current, I2 is the middle, and I3 is the right
Given:
R1=1000Ω R2=2000Ω R3=3000Ω R4=4000Ω
V1=V3=10V, V2=5V
For loop 1 (left):
-1000*I_1-10=0
-1000*I_1=10
For loop 2 (mid):
10-2000I2-3000I2+3000I3=0
-5000I+3000I3=-10
For loop 3:
-3000I3+3000I2-10-4000I3+5=0
3000I2-7000I3=-5
Putting this in matrix form and solving gives:
I1=-0.01A, I2=2.1mA, I3=1.923*10^-4A
Vout-R4*I3+V2=0
Vout=4000*1.923*10^-4 - 5
= -4.2308V
With the way Vout is drawn, it should be negative right?
Yes, that's correct.
Notice that you didn't need to consider Loop 1 at all.
This was how I did it. Same answer.
If you recognize that R1 is "hidden" from the rest of the circuit by V1 (and so can be eliminated from the circuit entirely), and that V3 forms a supernode of Vout, you can write a single node equation and solve for Vout.
Thank you everyone!
The second part of the question asks what the power produced by each voltage source is.
This is easy with the equation P=IV.
The exact wording is "What's the power produced by each source."
Generally speaking, if a current enters the positive terminal of the voltage source that means the power is positive, right?
If a current enters the negative terminal of the voltage source that means the power is negative?
For V_1, the net current enters the negative terminal of V_1.
If current exits the + terminal of a voltage source it is producing power (injecting energy into the circuit). If current enters the + terminal it is absorbing power (taking power out of the circuit). Whether you call the power positive or negative depends upon your point of view: are you adding up power being dissipated or power being generated?
