Circuits and automotive battery Question
In summary: In order to accurately calculate the energy expended, you must integrate the power (i(t)*v(t)) over the correct bounds, which in this case would be from 0 to 4 hours. Integrating over incorrect bounds will result in an incorrect answer because you are not accounting for the entire time period that the battery is being charged. It is important to carefully consider and understand the bounds of integration in order to accurately solve problems like this.
Matt1234
142
A constant current of 3 A for 4 hours is required to charge an automotive battery. If the terminal voltage is 10 + t/2 Volts, where t is in hours, how much energy is expended? (dw)
i = dq/dt
v= dw/dq (w = work in joules)
p = iv
[PLAIN]http://img203.imageshack.us/img203/2080/67548281.jpg
please advise
answer in the text is 475.2 Kilo Joules, i don't see how they get this, i keep getting 518.4.
The term in your integral cannot be a constant. You need to account for the fact that the charging voltage has to increase over time in order to keep the charging current at 3A. The power is not a constant 36W...
how do i setup such a question? i understand what your saying but not sure how to set this up
Your assumption that P = V*I = 12*3 is incorrect, as the voltage changes over the 4 hours.
Trying finding the average voltage (any method will do, but I integrated the voltage over the time period and then divided it by the time period) and then using this number in your calculations.
im sorry I am confused, i understand now that the voltage varies;
at t = 0 v = 10
at t =4 hours v= 12
i don't know how to setup this integral this is my most recent attempt:
[PLAIN]http://img88.imageshack.us/img88/4723/lastscaneb.jpg
following your steps i found the average voltage to be 11 volts.
Since the voltage is a linear ramp, using the average voltage may work. What answer do you get using the average voltage to get the average power and integrate that?
I'd still do it the full way, with the current equation (versus time) multiplying the constant current inside the integral. The integral is over time after all, and your voltage is V(t).
That integral you did looks good!
If you multiply the current by the integral of the voltage over 4 hours to get the power over 4 hours (what you just did), what bounds do you need to integrate the power between to get the work done?
The numbers are all there, its just in the understanding.
the bounds are the part I am having difficulty with because in the formula for voltage time is in hours where as in i = dq/dt time is in seconds so I am slightly confused.
What purpose does doing the integral of voltage have?
i took the integral of the voltage to obtain the average voltage.
No. The integral is the area under the curve i.e. the total summation of voltage over the entire period defined by the bounds of integration.
To get the average voltage, you have to ...
divide the total voltage over the time peroid by the upper limit.
Option 1:
Then don't multiply the integral through by the 3 A. Compute the integral (with the limits in units of hours), and get the answer in "volt-hours." Now you can convert the current into units of coulumbs/hr and multiply. Or you can convert the answer in volt-hours into an answer in "volt-seconds" and then multiply directly by the 3 A to get the answer.
Option 2:
Or you can convert *before* integrating. If v(t) = 10 V + t/2, both terms must have units of volts, which means that the constant factor of 1/2 multiplying the t must have units of hours/volt. You could convert this constant into units of seconds/volt, and integrate (also converting the upper limit of integration from 4 hrs into seconds). Then your answer will directly be in volt-seconds, which you can then multiply by 3 A.
Either way, you just have to be more careful about keeping track of your units by explicitly writing them out. And some sort of unit conversion will have to be done somewhere.
EDIT: Why the hell are you guys computing the average voltage anyway? To answer part (b), you need to compute the energy, which requires integrating p(t) with respect to time. Since p(t) is equal to i(t)*v(t), and i(t) is actually constant, you must integrate v(t) with respect to time (with the result of the integral being multiplied by the constant current value).
EDIT 2: Oh I see. The answer to my question is in what berkeman said at the beginning of post #8. Okay fine, but I agree with him that doing that is not any easier than computing the integral directly (since you still have to do that anyway!)
i understand it now.
I appreciate your help Zryn, cepheid and berkeman. Thanks.
What happens when you integrate v(t) with respect to time, multiply it with i(t) to get p(t), then integrate it over incorrect bounds to get work? You get the wrong answer, but also hopefully an explanation and understanding of where you went wrong.
First of all, this thread is now over. Second of all, based on your quoted description, I don't think you understand what I am suggesting. I am not suggesting integrating the voltage, multiplying it by i, and then integrating *that* a second time, because that would just be completely wrong. HERE is what I was suggesting:
[tex] i(t) = I = \textrm{const} [/tex]
[tex] E = \int p(t)\,dt = \int i(t)v(t)\,dt = I\int v(t) dt [/tex]
You integrate v(t) once and you have your answer (at which point you just have to be careful about units when plugging in the numbers). It's simple and it doesn't require the EXTRA step of computing the average voltage, which accomplishes nothing.
Third of all, I wouldn't have used the incorrect bounds, and I very carefully instructed the OP on how to avoid getting the units wrong in my previous post.
...based on your quoted description, I don't think you understand what I am suggesting. I am not suggesting integrating the voltage, multiplying it by i, and then integrating *that* a second time, because that would just be completely wrong...
integrating the voltage --> int 10 + t/2 from 0 to 4 = 4*[10t + t^2/4] = 44
multiplying it by i --> 44 * 3 = 132
integrating *that* a second time --> int 132 from 0 to 3600 = 3600*[132] = 475.2kJ
There was only a very slight problem with the OP's math and I was trying to work through it in a way that would (hopefully) show the problem, rather than say what the problem is and risk having the OP not actually understand, and then make the same mistake again, which seems to be quite common when people say they understand.
Well, the OP made a minor slip up with units and plugging in numbers, because it's not simple. Taking the extra steps to look at it in depth (hopefully) showed the problem, and hopefully it won't be made again. This accomplishes something, I believe.
I found when I was in university, that If I did the quick and easy math and made a simple mistake, I wouldn't get as many marks as compared to longer versions where the markers could see a simple mistake and the propagation of errors.
I also think that sometimes people who have been doing things for a long time can overlook the difficulty of doing things when you haven't mastered them, and it is generally better to do math with examples showing excruciating detail, rather than make the assumption that someone knows something and have them state at the end that they understand, because of terms such as 'its simple', 'its obvious' or 'its easy'.
So while this thread is over, please accept that there are many routes to the final goal, and doing things faster is not necessarily always the best thing, especially if you don't understand what is going on (I certainly don't most of the time :smile:).
I agree that the integral gives you an answer of 44 Vh, but I don't think that this factor of 4 should be out front.
Okay, so you've multiplied 44 Vh * 3 A to give you a result of 132 Wh. This is already in units of energy. This is the answer. If you were to integrate it with respect to time a second time, that would be wrong, because your result would then have dimensions of energy*time.
For some reason you are calling this integration, but it is NOT integration. It is merely unit conversion. What you have done is to take the 132 Wh and multiply it by 3600 s/h to get a result in Ws, also known as joules. This step is correct, which is why it leads to the correct answer, but it is certainly not integration.
I agree with everything you said in the rest of your post about how it is important to be a little more explicit with the steps of a solution when helping somebody who is just learning. However, the way in which you described those steps has not been correct in some cases.
guys thank you both so much, i wanted to prove to both of you because of your efforts I DO understand the problem. here is proof:
[PLAIN]http://img138.imageshack.us/img138/9182/lastscancs.jpg
when i first did the problem i had a hunch that the units were not quite right, and didnt know how to handle them, now i do.
thanks again for both your efforts.
Too true, you're right.
I was mistakenly doing the second integral due to thinking I needed to integrate the function to get the work, but I had already done the work in finding the function :smile:.
...guys thank you both so much, i wanted to prove to both of you because of your efforts I DO understand the problem ...
Awesome!
That's great, I'm really glad that you solved the problem and now fully understand the method. Nice work converting the current to units of coulombs/hr btw.
Zryn, sorry if I was a bit abrasive. You obviously helped the OP a lot, and everybody makes mistakes. Your suggesting an alternate method that delved into the mechanics of the problem a bit deeper probably did lead to greater understanding.
Related to Circuits and automotive battery Question
1. How does a circuit work?
A circuit is a path that electricity flows through. It consists of a power source, such as a battery, and wires that connect the power source to a device, such as a light bulb. When the circuit is complete, the electricity can flow from the power source to the device, allowing it to function.
2. What is the purpose of a fuse in a circuit?
A fuse is a safety device that is designed to break the circuit if there is too much current flowing through it. It acts as a barrier, preventing the excessive flow of electricity and protecting the circuit from damage or fire.
3. How do I determine the voltage and current of a circuit?
The voltage of a circuit can be measured using a voltmeter, which is connected in parallel to the circuit. The current can be measured using an ammeter, which is connected in series to the circuit. Both of these measurements are important in understanding how a circuit works and ensuring it is functioning properly.
4. What is the difference between a series and parallel circuit?
A series circuit has all of its components connected in a single loop, meaning that the current flows through each component in sequence. In a parallel circuit, the components are connected in separate branches, allowing the current to flow through each component simultaneously.
5. How does an automotive battery work?
An automotive battery is a rechargeable energy storage device that provides the necessary electrical power to start a vehicle's engine. It works by converting chemical energy into electrical energy, which is then used to power the starter motor and other electrical components of the vehicle.
  • Electrical Engineering
