Carid said:
Well, sir. I never tried to be rude to you unless, you yourself went into circles.
See this situation yourself. I asked a question, I showed everything as I understood. And you without even caring to read it all, say "Where is your work?" And then when I mentioned that I had already done my work, you realising it, should have helped me if you at all desired. But to the contrary-you thought I had done something so callous that it resulted in one of the greatest dishonours faced by men.
Till then I didn't lose my patience. I reposted the whole thing (mind it-wasting my time as well as the valuable space of this server). Then you as the gentleman you are, told that you don't know the problem urself. How do you think I should have felt?
And now you continue to misguide me. Neither helping me, nor letting someone else help me. For your info, the first method is wrong. The question asks for average force. The force vector is rotating, but with constant magnitude. I need the average, so the second method is correct. I have learned that recently- and hopefully I am 99% correct.
I don't want to sound rude again- but please give statements you are confident about. If you at all have a doubt, mention you are not sure. Your reply is always welcome.
This may well be my last post to help you.
I don't know, whether you still think that its me who needs manners?
By the way, there are a lot of people around who can guide me
correctly.
I've been turning your problem over in my mind for the last few hours and now have the solution.
Your first solution is the correct one.
The second fails because the force doing the reversal of momentum is only the vectorial part of the force which points in the direction of the arrival and departure of the bead.
Think it over, I recently learned that the second one was correct.
regards,
Ritwik
