Circular Motion of motorcyclist
The centripetal force required for the motorcyclist to navigate the curve is 2000N, which matches the maximum frictional force available, allowing her to make the turn safely. If she accelerates while on the curve, the required centripetal force will exceed 2000N, leading to a skid. Conversely, if she decelerates, the process of slowing down requires additional friction, which can also surpass the friction limit, resulting in a skid. The angle at which she leans while rounding the corner is determined by the balance of forces acting on her and the bike. A banked curve would provide additional support against the forces at play, enhancing safety and stability during the turn.
danago
A 50kg motorcyclist on a 100kg bike enters a tight curve of radius 30m at a speed of 20ms-1. The maximum frictional force the surface can provide is 2000N before the bike will skid uncontrollably.
  • Will she make the curve safely?
  • What will happen if she speeds up while on the curve?
  • What would happen if she tried to slow down while on the curve?
  • At what angle to the vertical does she lean her bike while rounding the corner?
  • Why would this curve be safer if it was banked?
a)
F_c=\frac{mv^2}{r}=\frac{150(20^2)}{30}=2000N
The centripetal force required to move in that circular path is 2000N, which is supplied by the friction, so she will JUST be able to travel that path.
b) If she speeds up, the centripetal force required to continue on that path exceeds 2000N, which cannot be supplied by the friction, so she will therefore skid out of control.
c) If she slows to below 20m/s, then the centripetal force required will be less than 2000N. The maximum friction from the ground is 2000, so she should still be able to maintain her circular path. Apparently, according to the answers, she will skid if she goes lower than 20m/s. Why is this? The answer says "Slowing down requires extra friction; she will skid"
Parts a and b I am ok with, but I am a little confused with part c. Any help would be great.
Thanks,
Dan.
Consider what has to happen to reduce the bike's speed. Kinetic energy must be lost through W=Fd between the tyres and the road. At the point where the bike is traveling 20ms-1 and requires additional friction to slow down, this will exceed the 2000N limit and the skid will occur.
You could also look at the acceleration needed to change speeds. Since F=ma then a force is needed.
