Circular Motion With Constant Angular Acceleration
A 600 g steel block rotates on a 1.20 m-long tube, experiencing a thrust force of 5.01 N while being subject to a maximum tension of 40.0 N and a coefficient of kinetic friction of 0.60. The calculations reveal that the block makes approximately 2.1 revolutions before the tube breaks. Initial confusion arose regarding the accuracy of the answer, but it was confirmed that the calculations were correct despite an earlier submission error. The discussion also touched on the potential impact of air flow from the tube, although it was deemed outside the current scope of the class. Ultimately, the problem was resolved, and the correct answer was acknowledged.
Hoophy
Question: A 600 g steel block rotates on a steel table while attached to a 1.20 m-long hollow tube. Compressed air fed through the tube and ejected from a nozzle on the back of the block exerts a thrust force of 5.01 N perpendicular to the tube. The maximum tension the tube can withstand without breaking is 40.0 N. Assume the coefficient of kinetic friction between steel block and steel table is 0.60.
If the block starts from rest, how many revolutions does it make before the tube breaks?
My variables and constants:
Steel Block Mass = m = 0.600 kg
Radius = r = 1.2 m
Maximum Tension = T = 40.0 N
Thrust/Tangential Force = F = 5.01 N
g = 9.8 m/s2
Weight = mg
Coefficient of Kinetic Friction = μ = 0.60
Normal Force = N
Friction = z
Centripetal Acceleration = ac
Angular Acceleration = α
Maximum Angular Velocity = ω
Maximum Tangential Velocity = v
Tangential Acceleration = at
a) I drew a partial free body diagram showing only the vertically acting forces Normal Force (up, positive y) and Weight (down, negative y)
b) I summed the forces in the vertical axis:
Fvertical: 0 = N - mg
c) I isolated N:
N = mg
d) I drew another partial free body diagram showing only Friction (z), Thrust, and Tension. The situation I used is one in which the Steel Block is directly North of the center-point of the circular path such that Tension points South, Thrust points West, and Friction points East.
I defined my coordinate system as:
1) Positive x is West
2) Positive y is South
e) I summed the forces in the y axis:
Fy: mac = T
ac = T/m
f) I summed the forces in the x axis:
Fx: mat = F - z
mat = F - μmg
at = (F/m) - μg
g) I did circular motion shenanigans:
ac = v2/r = T/m
See (e)
v = sqrt(Tr/m)
ω = v/r
ω = ( sqrt(Tr/m) )/r = ( sqrt[ (40)(1.2)/(0.6) ] )/(1.2) = 7.45356 rad/s
α = at/r
See (f)
α = ( (F/m) - μg )/r = F/(mr) - (μg)/r = (5.01)/( (0.600)(1.2) ) - (0.60)(9.8)/(1.2) = 2.05833 rad/s2
h) More circular motion shenanigans:
Kinematic Equation: ω2 = 2αΔθ
Δθ = ω2/(2α) = (7.45356)2/(2(2.05833)) = 13.4953 rad
i) I computed the number of revolutions:
Δθ/2π = (13.4953)/2π = 2.1478 revs = 2.1 revs
4. A note
2.1 revs is not the correct answer, nor is 2.1478 revs. Also I do not know what the correct answer is...
I don't know where I went wrong.
Thanks for taking the time to read this!
[EDIT] 2.1 revolutions is correct.
Using your analysis I get the same answer, but I wonder if we need to consider the flow of air in the tube. As that flows out from the centre it gains tangential velocity, and the work for that comes from the thrust.
Likes Hoophy
My class has not progressed that far yet (I don't even know if this is within the scope of that class) so I doubt they would expect us to model this. Of course, you had no way of knowing that. :oldsmile:
I just checked again, apparently my calculated answer is correct and I simply typed in the wrong number for my submission...
...I guess I'll mark this question as solved. :bugeye:
Thank you for responding!
Very good.
My thought doesn't help anyway. We would need more information about the flow. E,g. by making the air at very high pressure the pipe could be kept very thin, so hardly any air mass.
Likes Hoophy
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
