songoku
- 2,470
- 386
A point object of mass m is connected to an inertialess string of length L. The other end of which is fixed to a point O. At time t = 0, the object is assumed to begin to move horizontally in a vertical plane from the bottom point A (OA = L) in the clockwise direction with an initial speed Vo. If \sqrt{2gL} < Vo < \sqrt{5gL} (g=acceleration due to gravity), then at a point B the magnitude of the force acting on the object from the string becomes zero, where OB = L and the velocity of the object is perpendicular to OB. We restrict ourselves to the case 0 < \theta < \pi/2. From the point B, for a while, the object takes a parabolic orbit till a point C, where OC = L. In the case \theta = \pi/3, find the angle \varphi
I've found the speed V = \sqrt{gL sin\theta} and the initial speed Vo = \sqrt{(2+3sin\theta)gL}. I also got the maximum elevation (with respect to the location B) = \frac{V^2 cos^2\theta}{2g}
What should i do next?
thx
