Clarification of homework question meaning
  • Thread starter Thread starter physstudent.4
    Homework
The homework question involves calculating the relative uncertainty in an electron's momentum given its position uncertainty matches its de Broglie wavelength. The uncertainty principle states that ΔxΔp ≥ h(bar)/2, which is crucial for solving the problem. There was initial confusion about whether to find Δp or the ratio Δp/p, but clarification indicates that the focus should be on the relative uncertainty Δp/p. Understanding that Δx is related to momentum is key to solving the problem correctly. The discussion emphasizes the importance of accurately interpreting the question to arrive at the right solution.
physstudent.4
Suppose you measured the x-component of position of an electron to an accuracy
matching it’s de Broglie wavelength, i.e., Δx = lambda/2. What is the relative
uncertainty in the electron’s x-component of momentum, Δp/p?
ΔxΔp >= h(bar)/2
I just wanted to clarify that relative uncertainty is Δp, not Δp/p. My professor writes these questions and is currently sick, so I feel like he may have not been thinking completely clearly... I am finding Δp, and not the ratio Δp/p? I am pretty sure I merely need Δp.
I'm pretty sure that your professor does want you to find what the relative uncertainty is (which is Δp/p).
The key to this problem is that Δx depends on p.
ooh, okay, I got it now, thanks!
11K
