Classical description of laser light?
Laser light can be understood as a finite plane wave, characterized by its coherent and monochromatic properties. Mathematically, laser light is treated using a wave picture that incorporates plane waves along the beam's direction while the amplitude decreases radially, often modeled with a Gaussian profile. This Gaussian approximation aligns well with actual measurements of laser beams. However, the classical description of lasers is not commonly utilized in practice, as the unique properties of laser light often require quantum mechanical treatment. Understanding these aspects is crucial for grasping the nature of laser light.
dipole
It occurred to me today that I really don't know much about lasers. When dealing with electromagnetic waves, we always talk about plane waves, which are infinite in extent, or spherical waves, which spread out as they travel.
What then is laser light? A finite plane wave? How do you treat laser light mathematically using the wave picture?
Science news on Phys.org
You have plane waves in the direction of the beam but to get a beam the amplitude of the waves has to go to zero radially. The profile used is usually gaussian - which is close to actual measurements. But we don't normally use the classical description for lasers.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
