Classical Mechanics: Lagrangian of a falling yo-yo
The discussion focuses on deriving the Lagrangian for a yo-yo system with a moving support, specifically analyzing the equations of motion and energy expressions. The Lagrangian is defined as L = T - V, where T represents kinetic energy and V represents potential energy. The participant successfully derived Lagrange's equation, yielding the result \(\dot{}\dot{\varphi} = \frac{2}{3} \frac{g}{a}\). The relationship between the yo-yo's vertical position and the upward displacement of the support, h(t), is critical for understanding the system's dynamics.
  • Understanding of Lagrangian mechanics and generalized coordinates
  • Familiarity with kinetic and potential energy equations
  • Knowledge of rolling motion and the condition for rolling without slipping
  • Basic calculus, particularly in relation to derivatives and motion equations
  • Study the derivation of Lagrange's equations in classical mechanics
  • Explore the concept of rolling without slipping in detail
  • Investigate the implications of moving supports on dynamic systems
  • Learn about energy conservation principles in mechanical systems
Students and professionals in physics, particularly those studying classical mechanics, as well as engineers and researchers working on dynamic systems involving rotational motion and constraints.
NahsiN
A uniform circular cylinder (a yo-yo) of radius a and mass M has a string wrapped around
it that can unwind without slipping. The yo-yo moves in a vertical straight line and the
straight part of the string is vertical as well. The other end of the string is fastened to a
support that has upward displacement h(t) at time t. Here h(t) is a prescribed function, not
a degree of freedom.
a. Take the rotation angle φ of the yo-yo as a generalized coordinate and find Lagrange’s equation.
b. Find the acceleration of the yo-yo. What must the support’s acceleration h(t) be so
that the centre of the yo-yo can remain at rest?
c. Suppose the system starts from rest. Find an expression for the total energy E = T+V at time t, in terms of h and h.
L=T-V
T=\frac{1}{2}M\dot{y}^{2}+\frac{1}{2}I\dot{\varphi}^{2}
Defining downwards as my positive direction: V=-Mgy
Rolling without slipping ---> a\dot{\varphi}=\dot{y}
Since the support is moving upwards given by (h(t)) ---> y=\widetilde{y}-h(t) where \widetilde{y}= the distance between the yo-yo and the support at time t. So, \dot{y}=\dot{\widetilde{y}}-\dot{h(t)}
With these equations and treating \varphi as my generalized coordinate, it's easy to obtain the Lagrange's equation of motion for this system. I get \dot{}\dot{\varphi}=2/3*g/a
Now for part b) of the question, I have \dot{}\dot{y}=\dot{}\dot{h}. If this is correct, I can figure this out using the without slipping equation above.
From here on before starting part c), I am wondering why the Lagrange's equation I got is independent of h(t) (i.e its the same as if the support was fixed). And if its wrong, it has to do something with the relation between y and h(t). Any help is apprecaited
  • · Replies 42 ·
  • · Replies 36 ·
  • · Replies 24 ·
