Solving the Problem of an Infinite Chain Slipping Down a Table
The discussion revolves around solving a physics problem involving an infinite chain slipping down a frictionless table. Participants suggest using the Euler-Lagrange equations to derive a second-order differential equation by expressing the kinetic and potential energies. There is a debate about the implications of the chain's infinite length, particularly concerning its mass and motion. The conversation highlights the need for clarity on how to model the problem while addressing the challenges posed by the infinite nature of the chain. Ultimately, the participants are focused on applying theoretical physics concepts to resolve the paradox of the infinite chain's movement.
johnson12
Hello all, I'm having trouble with the following problem:
Pb: A chain with constant density and infinite length is slipping down from the table without friction. Determine the position of the tip of the chain at time t.
I know there are a few ways to approaching this problem, namely from Newtons equations, or lagranges equations, but I am quite rusty with this, so any suggestions would help a lot, thanks.
Hi,
do you know the Euler–Lagrange equations ?
You have to find an expression for the potential and kinetic energy,
the difference is the Lagrange-function. Put this function in the Langrange equations
and you get a second order diff.-equation.
kind regards
Hi johnson12! :smile:
Infinite length? … presumably only in one direction? :wink:
Use conservation of energy.
are you referring to this equation:
\frac{\partial L}{\partial x_{i}} - \frac{d}{dt}\frac{\partial L}{\partial \dot{x_{i}}} = 0, i=1,2,3
where L = T - U is the lagrange function,
how can I use this to model my problem?
(ps. I am apologize if my physics is wrong, unfortunately I am a math major).
Yes, but we need only one variable x_1 = y for example. Now you have to find an expression
for the kinetic energy T which is simple and for the potential energy U which is simple
as well. U depends of course at your point of reference. Make a sketch.
I get that T(\dot{x}) = \frac{1}{2}m \dot{x}^{2}
U(x) = mgx,
\frac{\partial L}{\partial x}= - m g
\frac{d}{dt} \frac{\partial L}{\partial \dot{x}}= m\ddot{x}
Lagranges equation implies m\ddot{x} + mg = 0
but I'm a little confused, if the chain is of infinite length, would it then have infinite mass?
so how can the chain move?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
