Classical particle distribution in a harmonic potential question
shad0w2000
Hi,
I have a question regarding how to find the probability of finding a classical particle at position x, in a harmonic potential.
I have a general probability function P(x) = C*exp(-1/T * V(x) ), where T is the temperature, but this just gives a Gauss-function naturally, but what I want is to make a graph like this:
http://demonstrations.wolfram.com/HarmonicOscillatorEigenfunctions/
I know this one is quantum mechanical, but for high quantum numbers I should get a similar looking graph (smooth, without all the peaks).
Can anybody tell me what I am doing wrong? I can't really see what I should do to get the correct result using this probability function.
I can add some more information about my question:
What I have is a list of position, velocity and acceleration values at each timestep in a verlet simulation.
If I make a histogram of the positions I get what I should get (high bars at the turning points).
This histogram should give a clear indication of the probability function describing the probability of finding the particle at some position x.
But, according to the Gibbs distribution we got:
P(x,v) = 1/Z * exp( -1/T * (½mv^2 + ½m*w^2*x^2 )
Where Z is the partitionfunction, normalizing P(x,v).
So integrating v out of the above equation gives
P(x) = K * exp( -1/T * ½m*w^2*x^2)
Where K is just some new normalizationconstant.
But how am I supposed to use this P(x) to compare with my histogram? As I wrote before P(x) is just a Gauss-function, and there must be something I'm missing or misunderstood.
I hope someone can help me :)
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
