Classical physics (phase diagram
The discussion focuses on analyzing the motion of a ball of mass m released from height h, leading to the derivation of its phase diagram. The equation v = sqrt(2g(h-x)) describes the relationship between velocity and distance from the ground as the ball falls. The graph of this relationship is a curve that starts at x = h and reaches its maximum velocity when x = 0. The x-intercept occurs at x = h (where velocity is zero), and the v-intercept is at y = √(2gh) (when the ball hits the ground). The participants clarify the graph's behavior, questioning whether it opens upwards or downwards.
dirac1902
A ball of mass m rests at times t less than 0, at height h above the ground. at time t=0 the ball is released and fell on the ground after hitting the ground, the ball rests there.
a) x represents distance from the ground, drive and expression for the phase diagram when the ball moving toward the ground. and draw it and find where v and x meet the axis's.
The attempt at a solution
1/2(mv^2)= mg(h-x)
v=sqrt(2g(h-x)) #
the graph will be a curve (square root) the start will be when x=h and then when it hits the ground will have max v so the position will be zero and v is max.
Thanks
1/2(mv^2)= mg(h-x)
v=sqrt(2g(h-x)) #
Thanks
It all seems fine to me. The question asks you for the point at which the curve meets the two axes (plural of axis by the way), in other words it asks for the the x-intercept and v-intercept. So you might want to state more explicitly that:
- the x-intercept (when v = 0) occurs at x = h
- the v-intercept (when x = 0) occurs at y = √(2gh)
but how the curve will be. I mean will it open up or down?
Thanks for your help :)
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 38 ·
  • · Replies 31 ·
  • · Replies 25 ·
