Maximizing Rotation: Solving the Clay & Pivoting Rod Problem
  • Thread starter Thread starter bcjochim07
    Clay Rod
The discussion revolves around a physics problem involving a rod and a ball of clay, focusing on calculating the maximum angle the rod will rotate after the clay sticks to it. Participants clarify that the moment of inertia for both the rod and the clay can be summed when calculated about the pivot point. They emphasize that energy is not conserved during the collision due to the inelastic nature of the event, where momentum conservation is more applicable. The correct approach involves using angular momentum to find the angular speed post-collision and then equating the rotational kinetic energy to gravitational potential energy at the maximum height. A mistake regarding the pivot point for the moment of inertia and center of mass calculations is also noted, highlighting the importance of accurate reference points in such problems.
bcjochim07
A 75 g 30 cm long rod hangs vertically on a frictionless, horizontal axle passing through its center. A 10g ball of clay traveling horizontally at 2.5 m/s hits and stick to the very bottom tip of the rod. To what maximum angle measured from the vertical, does the rod with attached ball of clay rotate?
I have a few questions as I am writing down things to start this:
Can I calculate the moment of inertia for the rod and the moment of inertia for the ball around the pivot point and add those together?
Then I think I'll use conservation of energy where K of the ball initial = the rotational kinetic energy of the clay and rod. Then somehow I have to equate that to potential energy. The trouble I'm having is can I just use mgh with the total mass of the ball of clay and the rod as m, or does the fact that this is an extended object make a difference?
bcjochim07,
Yes, the moment of inertia of the two objects about the pivot point is the sum of their separate moments of inertia about the pivot point.
There is a problem with using that the initial kinetic energy of the ball equals the rotational kinetic energy of the ball+clay. Energy is not conserved in the collision. But what is conserved?
The gravitational potential energy of an object depends on the height of the center of mass of that object (for these objects near the Earth's surface). You can either treat these as two objects and find two potential energies, or find their common center of mass and treat them as a single object.
Momentum is conserved in the collision. But why isn't energy conserved?
Energy is not conserved because the ball sticks to the rod. (Also, in collisions of everyday objects you can't assume energy is conserved. Unless somehow they let you know that the collision is elastic, you usually have to assume that energy is lost.)
Linear momentum conservation is not as useful as angular momentum in this case--the rod is rotating and so the entire rod has a common angular speed; different parts of the rod have different linear speeds.
Specifically about the non-conservation of energy for this problem, work is done in deforming the clay during the collision, heat is formed during the collision, etc. This work is not transformed back into kinetic energy at the end of the colliison.
Ok, so would for angular momentum, would this work
(.01kg)(.15m)(2.5m/s)= I* omega
where I is the moment of inertia of the rod with clay stuck to it
then I could use Krot= .5I*omega^2 and then equate that to a potential energy at the max height. For the potential energy, would I use the height of the center of mass?
That's right; the h in the potential energy term is based on the center of mass height.
so for the moment of inertia:
For the rod:
(1/3)(.075kg)(.30m)^2
=.00225 kgm^2
For the clay
(.01kg)(.15m)^2
=2.25E-4
add them: .002475 kgm^2
center of mass: [(.075kg)(.15m) + (.01kg)(.30m)]/.085kg = .1676 m from the pivot
solve for omega w/ angular momentum :
(.01kg)(.15m)(2.5m/s)= (.002475)*omega
omega=1.52 rad/s
Krot= potential energy at the max angle
.5*(.002475)(1.52 rad/s)^2=(.085kg)*g(.1676m-.1676costheta) theta= 11.62 degrees
For the rod:
=.00225 kgm^2
bcjochim07,
The pivot is at the center of the rod. This formula is for a rod pivoted at one end.
Also I think the same problem arises when you calculated the center of mass.
oh yep, I used the wrong pivot poi t
