CMRR in open loop and closed loop configuration of opamp
In op-amps, the Common Mode Rejection Ratio (CMRR) is calculated differently for open-loop and closed-loop configurations. The open-loop gain (Adm) is used for CMRR in open-loop setups, while the closed-loop gain is applied in closed-loop configurations. The discussion highlights confusion regarding the consistency of differential gain definitions across these configurations. It emphasizes that the differential gain in closed-loop systems does not refer to the open-loop gain, which can lead to ambiguity. Understanding these distinctions is crucial for accurate CMRR calculations in various op-amp applications.
anubhavsingh
For an opamp in open look configuration,
Here Ad should be equal to open loop gain of opamp and
Now consider the closed loop config of opamp (negative feedback used):
However, Ad is closed loop gain here (according to Sedra Smith) and
In terms of open loop gain,
A is open loop gain here.
So Adm is open loop gain in the first case and Adm is closed loop gain in the second case. How to know which gain to use in CMRR?
Reference: Microelectronic Circuits (Seventh Edition) by Sedra Smith
An op-amp is operated with negative feedback to maintain a low differential input voltage. An op-amp is NOT designed to be used as an open loop voltage comparator.
Sorry, I am a little confused and incomprehensible about your question.
You have proposed two different circuits, one is an open-loop amplifier and the other is a closed-loop amplifier, and you mentioned their respective voltage gains. If I understand correctly, your question is whether you should use open-loop voltage gain or closed-loop voltage gain to calculate their respective CMRR.
If you think in accordance with the general logic, isn't this thing relatively simple?
So my understanding is of course that the CMRR of the open-loop amplifier should be calculated with the corresponding open-loop gains, and the CMRR of the closed-loop amplifier should be calculated with the corresponding closed-loop gains. :smile:🐻
Yes, but why is that? Why can's the meaning of differential gain remains consistent whether the opamp is open loop or closed loop. Why should in closed loop configuration, the differential gain should not refer to the open loop gain of opamp as in open loop configuration? Just looks ambiguous to me.
Try this site, it describes/explains some of the details you are asking about.
https://www.electronics-notes.com/a...erational-amplifier-op-amp/gain-equations.php
Cheers,
Tom
To be honest, so far I don’t seem to be sure what the crux of the problem you want to discuss is.
But based on the CMRR-related content described in your first post, I believe the following article may be helpful to you. If you can fully understand the content of this article, including the equations mentioned, then your doubts may be solved.
https://www.analog.com/media/en/training-seminars/tutorials/MT-042.pdf
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
