What is the coefficient of discharge and why is it important?
The coefficient of discharge is a dimensionless number that quantifies the efficiency of fluid flow through an orifice or nozzle. It is important because it helps in predicting the actual flow rate compared to the theoretical flow rate. The discussion highlights confusion regarding the use of the coefficient of discharge in relation to the variable z, which represents a height difference with a specific dimension. Additionally, there are concerns about the author's use of dimensions in their equations, indicating a lack of clarity. Understanding the coefficient of discharge is crucial for accurate fluid dynamics calculations.
werson tan
why the author consider the coefficient of discharge as the z here ? what is exactly coefficient of discharge?
1. He doesn't . ##\Delta z ## happens to be 0.61 m here. You can check: it has a dimension. C has not. (*
2. Didn't google work ? Plenty links when I try !(*) the author is rather sloppy with dimensions. ##\rho_0## has a dimension too.
