Calculating Coefficients of Friction and Tension in a Two-Block System
The discussion focuses on calculating the coefficients of friction and tension in a two-block system involving an 8 kg mass and a 3.5 kg mass on an incline. Key calculations include the components of gravitational force and the normal force, with the normal force expressed as mg cos(θ) rather than sin(θ). The friction force is determined using the coefficient of friction multiplied by the normal force, but the coefficient remains an unknown to be solved. The total force acting on the system is derived from the gravitational components and friction forces, leading to an equation that can be solved for the coefficient of friction. Additionally, the calculated normal forces for both masses and the resulting tension in the string are discussed, with discrepancies noted between calculated and book values.
Freebunny
*note* This question has been deleted.
You appear to have correctly calculated the components of gravitational force acting on the two masses normal to and along the incline, though you may have gotten your right triangle confused (it is gravity itself that is "directly down", not the pull on the box: For the 8 kg mass they are FS= 8(9.8)sin(35) (FS is the force in the direction of the incline) and
FN= 8(9.8)cos(35). For the 3.5 kg mass they are
FS= 3.5(9.8)sin(35) and FN= 3.5(9.8)cos(35).
I also know the force of friction is equal to the coefficient of friction times the normal force. I think the normal force is mass times the sine of theta times gravity, but I don't know how to find the force of friction.
You almost said it! The normal force is mg cos(35) (not just mass times sin- mg times cosine-look at your diagram) and the friction force is the coefficient of friction times that. The problem is that, here, you are not given the coefficient of friction- that's the "unknown" you are asked to find. Let's call it "c". The friction force on the 8 kg mass is 8(9.5)cos(35) and for the 3.5 kg mass it is 3.5(8.9)cos(35).
The "S" component of gravitational force on the 8 kg mass is pulling it down the incline, the "S" component of gravitational force on the 3.5 kg mass is holding it back (through the rope) and both frictional forces are holding it back. Taking the positive direction down the slope, we have for the total force
F= 8(9.8)sin(35)- 3.5(9.8)sin(35)- 8(9.8)c cos(35)- 3.5(9.8)c sin(35)
= (8-3.5)(9.8)sin(35)- (8-3.5)(9.8)c cos(35)
= 4.5(9.8)sin(35)- 4.5(9.8)c cos(35).
We are told that the 8 kg mass has acceleration 1.5 m/s2 so we must have (F= ma) 4.5(9.8)sin(35)- 4.5(9.8)c cos(35)= 8(1.5).
Solve that equation for c.
Of the four forces, two (the "S" component of gravity on the 8 kg mass and the friction force of the 8 kg mass) are acting directly on the 8 kg mass. The other two (the "S" component of gravity on the 3.5 kg mass and the friction force on the 3.5 kg mass) have to act through the string connecting the two mass. The total of those two forces is the tension in the string.
I found the normal force on the 3.5 kg block to be 28.1 N and the normal force on the 8.00 kg block to be 64.2 N. Does this play at all into the equation? I was using F=coefficient of friction(normal force) before. When I went through the formula you suggested, I found the coefficient of friction to be .493.
In the book, the coefficient of kinetic friction is .0871 and tension is equal to 27.4 N.
When I try to get tension using the "S" component of gravity on the 3.5 kg mass and the friction force on the 3.5 kg mass, I figured the "S" component to be (3.5)(9.8)cos(35). I wasn't sure about the friction force, though. The friction force calculated above was for the whole system .. can still take (4.5)(9.8)sin(35)-(4.5)(9.8)cos(35) to get it?
