Collision between alpha particle and helium atom
The discussion centers on the collision between an alpha particle and a helium atom, specifically addressing why their tracks form a 90-degree angle post-collision. This phenomenon can be explained through the principles of conservation of momentum and energy in elastic collisions, particularly in two dimensions. When two bodies of equal mass collide, with one at rest, they can scatter at right angles due to the symmetrical nature of the collision dynamics. The conversation also emphasizes the importance of visualizing the collision in a 2D plane to understand the resulting trajectories. Overall, the 90-degree angle in their tracks is a direct result of these fundamental physical laws.
rogerkitkit
Why their tracks after collision has an angle 90 degree?
Any detail derive?
Any detail derive?
What have you tried and where did you get stuck?
Any detail derive?
Try solving 2D collision of bodies of equal mass, where one of them is initially at rest.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
10K
14K
