Collision of Atoms: Find Motion & Speeds
  • Thread starter Thread starter Dave218
    Atoms Collision
In an elastic collision, an atom of mass m collides with a stationary atom of mass 5m, resulting in the first atom moving in the y direction. The angle of motion for the second atom is calculated to be approximately 39.4° counterclockwise from the +x-axis. To find the speeds of both atoms after the collision, conservation of momentum principles should be applied, separating the momentum into x and y components. The initial calculations for the angle and one speed are correct, but further equations are needed to determine the second atom's speed. Visualizing the scenario with a diagram can aid in understanding the collision dynamics.
Dave218
An atom of mass m1 = m moving in the x direction with speed v1 = v collides elastically with an atom of mass m2 = 5m at rest. After the collision the first atom moves in the y direction. Find the direction of motion of the second atom. ________ ° counterclockwise from the +x-axis
Find the speeds of both atoms (in terms of v) after the collision.
v'1 = ________ v
v'2 = ________ v
(a) arctan(5) = 78.7/2 = -39.4° counterclockwise from the +x-axis
(b) tan(39.4) = .821 v = v'2
I don't know what formulas/equations to use here and am unsure on how to get v'2. I have worked out the correct answers for (a) and the first part of (b).
How about using the conservation of momentum to work it out? Split the momentum into individual components, in the x and y directions, and work from there. It also may help you visualize the situation if you draw the scenario out, both initial conditions, and final conditions.
