Does Gravitational Potential Energy Decrease on Collision?
In the discussion about gravitational potential energy (GPE) during a collision between two masses, it is clarified that the GPE decreases as the masses approach each other, becoming more negative. Initially, one might think GPE increases due to the inverse relationship with distance, but it is actually the opposite; the GPE becomes more negative as they get closer. After the collision, the GPE of the system is defined as a theoretical value since the masses cannot get any closer. If the masses are separated after sticking together, the GPE would then increase again. The conversation emphasizes the nature of GPE in gravitational interactions, particularly in terms of negative values.
utkarshakash
Two small bodies initially at rest and free to move from a distance of 1m from each other are subjected to only their gravitational force of attraction. They approach each other and collide and do not separate. In respect to this collision which of the following statement is true?
a)The total gravitational potential energy(GPE) of 2 masses has increased on collision.
b)The total gravitational potential energy(GPE) of 2 masses has decreased on collision.
I think option a) is correct as when the two bodies approach each other, the GPE increases as it is inversely proportional to distance. But option b) is the correct answer.
The GPE of one mass due to the other mass is always negative. It takes negative energy to move one mass from infinity to near the other mass. So the closer they get, the more negative the GPE.
OK. But what happens after they stick to each other? How does one define GPE of the system after that instant?
GPE can't change after the collision. It's now a theoretical number based on the fact that they can't get any closer to each other.
For point masses the GPE approaches -infinity.
EDIT: I shouldn't have said the GPE can't change after the collision. If you then separate the masses the GPE will increase again.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
